CCP1 in 18F1320 question
bebeto
PostPosted: Mon Aug 18, 2008 9:21 pm     Reply with quote
Hi guys, i try to use this code, but CCP1 value is inconstant.
Whats happening? I use in wrong way?
I use this code to measure frequency and start when one pulse is 2x old.
#int_ccp1
void handle_ccp1_int()
   if (flag==1)
      t1=ccp_1;
      setup_ccp1(CCP_CAPTURE_rE);
      flag=0;
      pulso++;
   }else{
      setup_ccp1(CCP_CAPTURE_fE);
      if (sync==0)
      if ( t1>tt+tt   )
         sync=1;
         pulso=1;
       set_timer1(0);
       flag=1;
       pulso++;
       tt=t1;
   if (sync==1) Mapa();
setup_timer_1(T1_INTERNAL | T1_DIV_BY_1);
setup_ccp1(CCP_CAPTURE_RE);
clear_interrupt(INT_CCP1);
enable_interrupts(int_ccp1);
PostPosted: Tue Aug 19, 2008 1:56 pm     Reply with quote
Read these threads on how to use the CCP to measure frequency:
http://www.ccsinfo.com/forum/viewtopic.php?t=29963
http://www.ccsinfo.com/forum/viewtopic.php?t=33153
PostPosted: Tue Aug 26, 2008 9:33 am     Reply with quote
CCP module work inconstant. I trie to measuring a square pulse and CCP value in printf is inconstant.
PostPosted: Tue Aug 26, 2008 10:12 am     Reply with quote
The CCP works.
Plenty of people have used it with no problems.
Likeliest thing to cause trouble, is the signal levels. The CCP, uses a _Schmitt_ input, which requires the input to go up to 0.8* the supply voltage, and down to 0.2* the supply. The latter is not a problem, but the former is higher, than is guaranteed by things like a 'normal' TTL output. If your signal is not reliably doing this, then you will get erratic behaviour.
bebeto
PostPosted: Tue Aug 26, 2008 1:26 pm     Reply with quote
the input signal level.
I make some measuring to check signal level and dont find problem.
If i run program in proteus all work fine, but if i write in pic and run the measuring results is diferent.
timer 0 didn't work wwith have ccp (timer1) process?
Ttemah
PostPosted: Tue Aug 26, 2008 2:52 pm     Reply with quote
How to not show useful data....
You don't show what the zero volt level is. If B is the zero level (which is what the graph looks like), then it looks as if this signal is swinging to something like +2v, and -2.5v. This will never work. You would need to connect it's ground to a voltage of about 2.5v...
I'd suspect this is where your problem lies.
bebeto
PostPosted: Wed Aug 27, 2008 11:23 am     Reply with quote
Ttemah
Channel 1 as 16f628 output to 18f1320 input.
Channel 2 is a 3ms 18f1320 output.
Time hight in channel 1 is 200us.
PostPosted: Wed Aug 27, 2008 2:50 pm     Reply with quote
The channel two display, shows the channel reference level near the _bottom_ of the waveform. The channel one display, shows the reference level in the _middle_ of the waveform. Then channel 2, is shown as having a unit amplitude of 50v, not 5v. Suggests you have the scope set for *10 probes, and the probe set to *1, otherwise how can the logic output from the chip give such an amplitude?...
Set both probes to *10, make sure the scope is set to use *10 probes, set the vertical scale to 5v, and set the cursor level to 0v, then we can see what the waveforms actually represent.
So far, the information is still useless.
