lcd bar graph... it goes also to the left?
bgvsan
PostPosted: Sun Aug 24, 2008 5:45 pm     Reply with quote
I need some help to solve a little problem..
I found this code on this forum..
http://www.ccsinfo.com/forum/viewtopic.php?t=22965
this is great and works!
But now i put the beginning of the bar, in the middle, and goes to the left for ADC value from 0 to 255 and to the right from 256 to 512.
The problem is to put the bar to the left... here is "my" code.
long value;
int A;
void main() {
   setup_adc_ports(RA0_ANALOG);
   delay_us(20);
   init_user_chars();    // loads special characters into LCD CGRAM for bargraph
   set_adc_channel(0);
   delay_us(10);
      value=read_adc(); //read the ADC
      delay_us(50);     //pause so we don't blur the LCD display
      A=(value/17)*2;       //calculate the full scale for our bar//raddoppiato per tensioni di 5 volts
      lcd_putc('\f');   //clear the LCD
      printf(lcd_putc, "value = %lu \n",value); //Print top line with ADC value
      if (value<=255){
         lcd_putc(A);
         bargraph_back(A);      //print line 2 with the bargraph output.
         bargraph(A);  //print line 2 with the bargraph output.
How should i create the bargraph_back? Rolling Eyes
treitmey
PostPosted: Mon Aug 25, 2008 10:11 am     Reply with quote
I think you want to overwrite the area defined for bar with spaces.
This will clear the bar graph.
Then redraw with new value.
bgvsan
PostPosted: Tue Aug 26, 2008 2:03 am     Reply with quote
i've found the solution... at 3.00 A.M. Twisted Evil
void bargraph_back(BYTE percent) {
//**************** Variabili****************//
   int Bars;               // Numero di barre intere.
   int Balance;            // Numero di barre ancora da scrivere non intere.
   int i, ind;
   Bars = percent/3;       // Quante sono le barre intere da 3?
   Balance = percent%3;    // Conta se ha bisogno di porzioni di barre
   lcd_gotoxy(20,2);       // sposta il puntatore in posizione 20 II spam(meta negativa lcd)
   ind=19;                 //inizia dalla posizione 19
  for (i=0; i<Bars;i++)
   {  output_high(PIN_A1);
      delay_us(100);
      output_low(PIN_A1);
      lcd_putc(0x02);      //Utilizzo putc per evitare l'<umento in posizione.
      lcd_gotoxy(ind,2);
      ind=ind-1;}          //Riporto l'indirizzo Ram 1 posto indietro.
  switch (Balance) {       //Mostra le barre restanti
      case 0: break;
      case 1: lcd_putc(0x03);break;
      case 2: lcd_putc(0x04);break;
this is the function for any one who wants your bar goes like this
* ||||||||||||||||||||* forward
*||||||||||||||||| *back
But now i need an extra Help---
I need to show to display a variable float----
example: G= 2,007896
* |||||||||||||||||||G2,00*
only 2 char after the comma.
crystal_lattice
PostPosted: Tue Aug 26, 2008 5:04 am     Reply with quote
When I have some time I would like to give your code a try as I have a battery level indication application where this will work nicely!
In your code add a call to the lcd_gotoxy() and set the co-ordinates to be just behind/before the end/start of the bar depending on your application. Then use printf("G%2.2f", your_float). This will give you two decimals before and after the "." and will start printing at the co-ordinates you specified.
bgvsan
PostPosted: Tue Aug 26, 2008 5:45 am     Reply with quote
compiler send back an error
STDOUT not defined (may be missing #rs232)
the error is on the float variable (is declared as global)
any other solution?
bgvsan
PostPosted: Tue Aug 26, 2008 4:17 pm     Reply with quote
i found
 printf(lcd_putc, "\g%1.2f", G);   //Visualizza il valore dell'ADC.
from lcd.h
case '\g'   : lcd_gotoxy(37,2);       break;
[URL=http://g.imageshack.us/g.php?h=299&i=lcd2ca4.jpg][IMG]http:
