Problem with function parameters
JacquesB
PostPosted: Fri Aug 22, 2008 2:01 pm     Reply with quote
If I try to pass a 16bit integer to a function I get this message :
Error 112 "test3.c" Line 14(1,1): Function used but not defined: ... Test SCR=393
The code looks like this
include <18F2525.h> // preprocessor directive that selects the chip
void Test(long); // function prototype
{ long a;
a= 0xffff;
Test(a);
void Test(x)
long i;
i=x;
It is the same whether I use long or int16. The function prototype looks ok. If I replace long by int8 it works!
I'm using compiler version 4.071
What am I doing wrong?
PostPosted: Fri Aug 22, 2008 2:36 pm     Reply with quote
Your prototype, needs to match your definition, and _both_need to define the variable. So:
void Test(long x); // function prototype
   long a;
   a= 0xffff;
   Test(a);
void Test(long x)
   long i;
   i=x;
JacquesB
PostPosted: Mon Aug 25, 2008 9:35 am     Reply with quote
I knew it had to be such a stupid mistake...
thanks
