microJuan
fast clock SPI |
Posted: Sun Aug 24, 2008 4:36 pm |
Hi folks, I apologise if this topic has been covered already but I didn't have luck finding a related post and I am new to picc.
Is it possible to read a 16 bit sync serial signal that gets updated at 16kHz ? Can I use spi_read( )? If so, could someone please point me in the right direction with the code.
Many thanks
Juan |
Posted: Sun Aug 24, 2008 7:24 pm |
If you want help, tell us the manufacturer and part number of the SPI
device that provides the 16-bit data. Also post a link to the data sheet
for the device. |
microJuan
Posted: Mon Aug 25, 2008 1:09 am |
the device datasheet can be found in www.finger-kg.de/lieferprogramm/micrometer/tastende_laser/doku/files/SLS7000Manfi.pdf
Figure 220 on page 22 shows the data output format. I have used two max485's (in receiver mode) one for the data signal and the other for clock signal. The outputs of these max485 comes up nicely on a CRO. I can see the clock signal as well the data signal.
Any suggestions as to how I can read this signal would be of great help.
Many thanks
Juan |
Posted: Mon Aug 25, 2008 10:02 am |
Yes, you should be able to receive this with the SPI hardware.
The bit order is right for SPI.
You would need to run the PIC as slave, with CKP=0, and CKE=0.
I can't see any real problems, except possibly needing to implement a 'synchronise' routine. I'd suggest that on the PIC waking, or if the checksum fails, you disable the SPI hardware, and sit monitoring the clock line. You look for a gap in the clock, longer than the 1/16000th of a second between bits, and when this is seen, restart the SPI. This way, you will be synchronised to the clock from the device, and regain sync, if it gets lost.
