18F6722 serial interrupt problems.
M0KHZ
PostPosted: Sat Aug 16, 2008 9:03 am     Reply with quote
Any pointers as to what I'm doing wrong here!
I'm trying to populate a FIFO using a serial interrupt routine.
To prove the comms ports are set up the code below (without the ISR) works fine:
#include <18F6722.h>
#device ICD=TRUE
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES HS                       //High speed Osc (> 4mhz)
#FUSES NOPROTECT                //Code not protected from reading
#FUSES BORV25                   //Brownout reset at 2.5V
#FUSES NOPUT                    //No Power Up Timer
#FUSES NOCPD                    //No EE protection
#FUSES NODEBUG                  //No Debug mode for ICD
#FUSES LVP                      //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES NOWRT                    //Program memory not write protected
#FUSES NOWRTD                   //Data EEPROM not write protected
#FUSES NOWRTC                   //configuration not registers write protected
#FUSES NOWRTB                   //Boot block not write protected
#FUSES NOEBTR                   //Memory not protected from table reads
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES NOCPB                    //No Boot Block code protection
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=COM2)
#use rs232(baud=9600,parity=O,xmit=PIN_G1,rcv=PIN_G2,bits=8,stream=COM1)
// Definitions
boolean serialHasData();
int8 serialRead();
char value;
/// Size of serial input port FIFO in bytes.  Must be a power of 2, i.e. 2, 4, 8, 16, etc.
#define SERIAL_BUFFER_SIZE 128
/// Mask to wrap around at end of circular buffer.  (SERIAL_IN_BUFFER_SIZE - 1)
#define SERIAL_BUFFER_MASK 0x7f
/// Index to the next free location in the buffer.
int8 serialHead;
/// Index to the next oldest data in the buffer.
int8 serialTail;
/// Circular buffer (FIFO) to hold serial data.
int8 serialBuffer[SERIAL_BUFFER_SIZE];
void serialInit()
    serialHead = 0;
    serialTail = 0;
//   Determine if the FIFO contains data.
//   & return true if data present; otherwise false
    return true;
void main(){
   serialInit();
   while (serialHasData())
    serialBuffer[serialHead] = getc(COM1);
    fputc(serialBuffer[serialHead],COM2);
    // Move the pointer to the next open space.
    serialHead = (serialHead + 1) & SERIAL_BUFFER_MASK;
However as soon as I initiate the ISR (code below), the IRS isn't triggered and hence nothing is pushed to COM2
#device ICD=TRUE
// Definitions
int8 serialRead();
int8 serialHead;
int8 serialTail;
#INT_RDA
void serialISR()
    // Save the value in the FIFO.
void serialInit()
    serialHead = 0;
    serialTail = 0;
     if (serialHead == serialTail)
        return false;
    return true;
void main(){
   enable_interrupts(INT_RDA);
   serialInit();
   while(true)
            fprintf(COM2,"\nCaptured something in the FIFO - progress at last!\n");
Has anyone any thoughts?
Kevin - M0KHZ
PostPosted: Sat Aug 16, 2008 11:37 am     Reply with quote
The first hardware UART is on pins C6 and C7. The 2nd UART is on
pins G1 and G2. You have named them the opposite way.
That may cause confusion. From the data sheet:
The pins of EUSART1 and EUSART2 are multiplexed with the
functions of PORTC (RC6/TX1/CK1 and RC7/RX1/DT1) and
PORTG (RG1/TX2/CK2 and RG2/RX2/DT2), respectively.
Here's where it caused a problem in writing your code.
#INT_RDA
void serialISR()
But the interrupt directives are associated like this:
#INT_RDA = pins C6, C7
#INT_RDA2 = pins G1, G2
If you give the 2nd UART the name "COM2", it would be more clear
that you should use #INT_RDA2 for its isr. It's easier to make the
correct choice when you're writing code.
#FUSES LVP
Also, this fuse should be NOLVP. Hardly anyone uses a low voltage
programmer. All commerical programmers are the high voltage type.
PostPosted: Sat Aug 16, 2008 11:41 am     Reply with quote
For extra stability add the ERRORS directive to the serial port setup. This causes the compiler to add code for clearing the error status bits at very getc call. Without this the UARTS will stall when the input buffer overflows (at 3 characters).
M0KHZ
PostPosted: Sun Aug 17, 2008 2:57 am     Reply with quote
THANKS guys, you've really helped sort out a big headache! the FIFO is now filling on interrupt Very Happy
All I have to do now is sort out the rest of the code!
Kevin - M0KHZ
