Stream as a parameter in a function
Eastfield
PostPosted: Fri Aug 08, 2008 7:17 am     Reply with quote
hi all,
i am wondering how to use a stream as a parameter ?
i would like to do something like this :
void debug(stream _stream)
fprintf(_stream,"in this stream %?",stream);
thanks.
gribas
PostPosted: Wed Aug 13, 2008 7:48 am     Reply with quote
I don't think that's possible. The compiler expects a constant for the first parameter of fprintf();
this works, but it's kinda useless:
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=SERIAL)
   const int stream = SERIAL;
   fprintf(stream,"test");
What about defining a debug stream? Like this:
#device PASS_STRINGS=IN_RAM
#define DEBUG_STREAM SERIAL
void debug(char* msg) {
   fprintf(DEBUG_STREAM,"%s",msg);
   debug("test");
