Wrong data on the software UART
Goto page 1, 2  Next
tranz
View user's profile Send private message Send e-mail Yahoo Messenger MSN Messenger
PostPosted: Tue Aug 12, 2008 8:50 am     Reply with quote
Hey guys,
I have interfaced 16F877A with 18F4620 and defined software UART pins to make them communicate with each other.
Code for 18f4620
#use rs232(baud=9600, xmit=PIN_C1,rcv=PIN_C0, STREAM=HOSTPC)
    BYTE c='A';
    fputc(c, HOSTPC);
    c='B';
    fputc(c, HOSTPC);
Code for 16F877A
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8, STREAM=HOSTPC)
#include <stdio.h>
#include "lcd2.c"
      byte d,c,x,output;
       lcd_init();
      c=fgetc(HOSTPC);
      printf(lcd_putc, "\fValue= %2X", c);
       output_high(PIN_C1);//LED high
       output_low(PIN_C1);//LED low
I am not getting A and B on the LCD output, for 'A' I get "F0", for 'B' I get "F1".
Any Suggestions?
treitmey
PostPosted: Tue Aug 12, 2008 10:18 am     Reply with quote
Just a thought, but on the 16F877A yoiu are using a REAL hardware usart pins.
That might be mixing it up.
Try the whole interupt and hardware usart firmware on the 16F877a
see C:\Program Files\PICC\Examples\EX_SISR.C
tranz
PostPosted: Tue Aug 12, 2008 12:27 pm     Reply with quote
Here is the new code with the suggested modification
#define BUFFER_SIZE 32
BYTE buffer[BUFFER_SIZE];
BYTE next_in = 0;
BYTE next_out = 0;
#int_rda
void serial_isr() {
   int t;
   buffer[next_in]=getc();
   printf(lcd_putc,"\fValue= %2X",buffer[next_in]);
   t=next_in;
   if(next_in==next_out)
     next_in=t;           // Buffer full !!
BYTE bgetc() {
   BYTE c;
   while(!bkbhit) ;
   c=buffer[next_out];
   return(c);
   lcd_init();
   enable_interrupts(int_rda);
   enable_interrupts(global);
   printf(lcd_putc,"\r\n\Running...\r\n");
               // The program will delay for 10 seconds and then display
               // any data that came in during the 10 second delay
   do {
      printf(lcd_putc,"\r\nBuffered data => ");
      while(bkbhit)
        putc( bgetc() );
   } while (TRUE);
But still its showing the same output as the previous one, one thing in common is "F" preceding a number, e.g. 'B' = F4; '2'= F1
I think the data is getting corrupted somehow, but cant point the finger where.
Suggestions?
PostPosted: Tue Aug 12, 2008 1:43 pm     Reply with quote
Your programs are not complete; missing the #fuses lines, etc.
What is your compiler version number?
For the PIC18F4620 the CCP2 module has priority over digital I/O on pin C2. Some compiler versions disable this module automatically, but to make sure it is best to add to start of your main the following instruction:
setup_ccp2(CCP_OFF);
tranz
PostPosted: Tue Aug 12, 2008 1:55 pm     Reply with quote
Thanks ckielstra, but it did not help. I am still getting the same outputs as before.
PostPosted: Tue Aug 12, 2008 3:26 pm     Reply with quote
For me to reproduce your problem you will have to answer the other two issues mentioned in my previous post:
1) What is your software version number?
2) Add the missing items from your example programs (#fuses, etc).
And coming to think of it a few more questions:
3) You are testing on real hardware or using a simulator program like Proteus?
4) If using real hardware, what voltages are both chips running at?
5) How is the physical connection between the two chips established?
- MAX232 or similar driver chips?
- Distance between the devices?
- etc.
tranz
PostPosted: Tue Aug 12, 2008 4:10 pm     Reply with quote
The version of the compiler being used is 4.073.
The fuses on 18F4620 are
#include <18f4680.h>
 #use delay(clock=40000000)
 #fuses H4
 #fuses NOFCMEN
 #fuses NOXINST
 #fuses NOIESO
 #fuses NOPBADEN
 #fuses MCLR
 #fuses NOWDT
#fuses NOPROTECT
#fuses NODEBUG
#fuses NOSTVREN
 #fuses PUT
 #fuses NOLVP
 #fuses NOBROWNOUT
 #fuses NOCPD
 #fuses WRT
 #fuses NOWRTD
 #fuses NOEBTR
 #fuses NOCPB
 #fuses NOEBTRB
 #fuses WRTB
The fuses in 16F877A are
#include <16F877A.h>
#fuses HS,NOLVP,NOWDT,PUT
I am testing this with real hardware, and the pins above mentioned are connected directly i.e. TX to RX and vice versa.
Both these micros are running at 5V and the distance between them is about 3mm.
Do you think the difference in clock speeds can be a cause of this? if so how do you think I can rectify this?
Regards
PostPosted: Tue Aug 12, 2008 5:57 pm     Reply with quote
This shouldn't be a problem. The compiler will warn you if a certain baudrate can not be achieved for your clock speed.
I don't know what is causing your problems. The fuses you have specified look OK and your compiler version v4.073 is a good one.
 #fuses H4
It's better to locate the '#use delay' instruction after the #fuses are specified. In this setup it's no problem but I just found out compiler v4.077 has a bug if you specify the internal oscillator (INTRC_IO).
Try to narrow down the problem. Figure out a test to proof which of the two systems is at fault. For example by measuring the serial signal with a scope.
A wild guess is that one of the two systems is running with a clock speed off by a factor 4. This is easy to test by blinking a led every second. Use a stopwatch to measure a 10 second period (don't count by head).
Another test worth trying is to run the PIC18F4680 on the internal oscillator without PLL:
#fuses INTRC_IO
... other fuses
#use delay(clock=8MHz)  // Note: this line _after_ the fuses (compiler v4.077 bug).
tranz
PostPosted: Wed Aug 13, 2008 7:51 am     Reply with quote
Thanks Ckielstra,
The system is now working, the problem was with the baud rate, since 16f was running at 20MHz and 18F was running at 40Mhz, I calculated the available baud rate ranges on both these clock rates, 9600 was way to low.
So the solution was going for a higher baud rate. the 18F is now running at 19800 baud and the 16F at 38400 baud. With this, the data is being displayed perfectly.
Cheers
drh
PostPosted: Wed Aug 13, 2008 8:20 am     Reply with quote
You still have a problem. The "system" should work with the same baud rates.
David
tranz
PostPosted: Wed Aug 13, 2008 8:52 am     Reply with quote
Well the data seems to come out fine. I have checked it with various inputs, and it displays the correct output.
I am also confused with the results, but it seems to work.
drh
PostPosted: Wed Aug 13, 2008 2:54 pm     Reply with quote
What is the frequency of the xtal used with the 18F4680 ?
David
PostPosted: Wed Aug 13, 2008 5:41 pm     Reply with quote
It's not good when you have to select two different baud rates to make it work.
I checked the fuses generated by your v4.073 compiler and these are correct.
The code for setting the baudrate on the PIC16F877A to 9600 baud is also correct. Leaving the PIC18 with the software UART as the most likely error source.
Have you performed one of the tests I suggested?
Oops.... you are mixing the configuration of two different processors here....
Which is the one you are using
tranz
PostPosted: Thu Aug 14, 2008 7:14 am     Reply with quote
18F4680 is the one being used in this case, sorry my bad it was a typo.
PostPosted: Thu Aug 14, 2008 2:54 pm     Reply with quote
Have you tried to narrow down the problem to one of the two PICs?
I suggested some tests...
Goto page 1, 2  Next
Page 1 of 2
