Problem using a struct from main. in other files.
PostPosted: Fri Aug 08, 2008 3:00 pm     Reply with quote
Hi
Problem using var from main. in other files.
My test project is:
1 main.c and 1 test.c
In main.c
struct _pos{
 int x;
 int y;
}pos;
int pos_main(){
 return (pos.x+4);
in test.c I can use the function "pos_main" but not access the struct?
I know I can put the struct in a .h file and then #include it in main.c and test.c but I dont.
any hints?
RLScott
Re: Problem using a struct from main. in other files.
PostPosted: Fri Aug 08, 2008 3:03 pm     Reply with quote
Anonymous wrote:
...I know I can put the struct in a .h file and then #include it in main.c and test.c but I dont...
Why don't you? That's what I would do.
Robert Scott
Real-Time Specialties
Embedded Systems Consulting
Wayne_
PostPosted: Mon Aug 11, 2008 2:18 am     Reply with quote
The other option is to define it as an extern within test.c
Something like
extern struct _pos{
 int x;
 int y;
} pos;
This then allows you to reference pos within test.c.
I have not tested this with CCS but it is standard C to reference an external variable.
