i am wondering how to use a stream as a parameter ?
i would like to do something like this :
void debug(stream _stream)
fprintf(_stream,"in this stream %?",stream);
thanks.
Posted: Sun Aug 10, 2008 1:42 pm
I don't think you can do this at run-time. I think it's hard-coded at
compile time (to use the specified stream).
kender
Re: stream as a parameter function ?
Posted: Sun Aug 10, 2008 7:52 pm
This question was brought up in the past in this thread: http://www.ccsinfo.com/forum/viewtopic.php?t=31264
Unfortunately, it was found that the stream is assigned at compile time. _________________ Read the label, before opening a can of worms.
