I want extract the single digit from a int8:
PostPosted: Sat Aug 09, 2008 2:51 am     Reply with quote
Hi
169 I want c1=1/c2=6/c3=9
I made this func for testing. Working but not nice.
void Get_Digit(void){
//want to isolate the digit
//ex. 169: c1=9/c2=6/c3=1
     int t,c1,c2,c3,tmp;
     t=169;
     //any hints for optimizing
     c1=t%10;
     c2=(t-c1)/10%10;
     c3=(t-(t%100))/100;
     tmp= c1+c2*10+c3*100;
     printf("t:%u c1:%u c2:%u c3:%u tmp:%u",t,c1,c2,c3,tmp);
Any suggestion?
SherpaDoug
PostPosted: Sat Aug 09, 2008 6:15 am     Reply with quote
What you have is fine. If you must go a little faster you can subtract in a loop instead of dividing. It will save a few machine cycles but the code is harder to understand so I don't recommend it unless timing is crucial.
Indy
PostPosted: Sat Aug 09, 2008 5:01 pm     Reply with quote
If you use an array instead of 3 separate variables you could do it like:
int8 c[3];
int8 value = 169;
for (i=3; i>0; i--)
  c[i-1] = value % 10;
  value = value / 10;
PostPosted: Sun Aug 10, 2008 2:12 am     Reply with quote
languer
PostPosted: Mon Aug 11, 2008 1:03 am     Reply with quote
If you only want to display digits, you can use sprintf.
char c[4];
sprintf(c,"%u",value);
