I2C weirdness
Ringo42
I2C weirdness
PostPosted: Fri Aug 08, 2008 11:02 am     Reply with quote
I'm using the latest compiler (4.077?) and a PIC 18F452.
I'm talking to the pic using I2C. I'm sending it data about every 30-40ms. There are 7 identical setups on the bus(except for address). After a few minutes the one or 2 of the boards will randomly stop responding. Timer 2 is still firing, and the Serial interrupt still works. I put in some code so that after it quits responding I send a serial packet to the board and it responds with the data in the I2C buffer. It seems that whenever it gets in this condition then all the data in the buffer is the same, it is the address of the PIC.
#INT_SSP
void ssp_interupt()
    int i;
    BYTE incoming, state;
//    int pinnumber,pinstate;
   state = i2c_isr_state();
    currentstate=1;
   if(state < 0x80)                     //Master is sending data
       incoming = i2c_read();
        buffer[bytecounter]=incoming;
        bytecounter++;
       if(bytecounter ==7 )              //First received byte is address
            bytecounter=0;
                if(buffer[1]==16)                 //PWM
                        bigcounter++;
//                        printf("pwm %ld\r\n",bigcounter);
                    ramp=buffer[2];
                    ID1 =buffer[3];
                    pwm1=buffer[4];
                    ID2 =buffer[5];
                    pwm2=buffer[6];
//                    sprintf(SERIAL_BUFFER,"pwm r:%d %d:%d %d:%d\0",ramp,ID1,pwm1,ID2,PWM2);
                    sprintf(SERIAL_BUFFER,"pwm %d:%d %d:%d\0",ID1,pwm1,ID2,PWM2);
                    pwm();
                    if(debug==1)
                        printf("%s",SERIAL_BUFFER);
                else {}
        if(bytecounter>7)// too many bytes, something is wrong
            bytecounter=0;
            return;
   if(state == 0x80)   //Master is requesting data
          for(i=0;i<15;i++)
                delay_ms(1);
//              i2c_write(values[i]);
      actionflag=1; //0 = nothing, 1 = read, 2 = change address
      bytecounter=0;
   currentstate=2;
So when I get a serial packet I'm doing this
       printf("bytecounter = %d \r\n",bytecounter);
        for(i=0;i<7;i++)
            printf("buffer%d = %d \r\n",i,buffer[i]);
and it comes back with something like
buffer0 = 68
buffer1 = 68
buffer2 = 68
buffer3 = 68
buffer4 = 68
buffer5 = 68.... and 68 is the address to the board.
So to me it looks like
incoming = i2c_read(); is always returning the same thing (after it gets in this weird mode)
Any idea what would cause this?
Or any way to get out of it if I detect I'm in it?
It works for anywhere from 30 seconds to 30 minutes then a board will randomly get this way. resetting the board brings it back to operational.
Any help will be greatly appreciated.
Ringo Davis
PostPosted: Fri Aug 08, 2008 11:23 am     Reply with quote
I don't really know, but just scanning your code, it has massive delays
throughout the isr. It has sprintf, printf, delay_ms() in a loop, and it calls
a pwm() routine.
I would start by commenting all of these massive delays, and then see
if you still get the lockup. Get rid of that loop. Change it so it just
transmits one byte. In other words, strip down the program to the
minimum and test it.
PostPosted: Fri Aug 08, 2008 11:29 am     Reply with quote
From the release notes:
4.077 Some problems with slave I2C have been fixed, see the newest EX_SLAVE.C
I haven't checked the changes CCS made to i2c_isr_state function but looking at the new ex_slave.c example it requires a (minimal) change to your ISR function.
to:
   if(state <= 0x80)                     //Master is sending data
Ringo42
PostPosted: Fri Aug 08, 2008 11:34 am     Reply with quote
Thanks, I'll make minor change using the <= and I'll start stripping out stuff and see if minimal code works ok.
Ringo
Ringo Davis
Ringo42
PostPosted: Sat Aug 09, 2008 1:09 pm     Reply with quote
The new ex_slave shows
The latest version of ex_slave.c has something I don't understand.
      if(state == 1)                     //First received byte is address
         address = incoming;
      if(state == 2)                     //Second received byte is data
         buffer[address] = incoming;
      i2c_write(buffer[address]);
How can it be master sending if it is <=80 and
master requesting if it is =80
80 would trigger both, is this correct?
I took out all the delay stuff now It has been running for about an hour with no issues, so I'm hoping it is fixed.
It would be nice however to have code in place so that if it happens again it can correct itself. Is there a way to reset the I2C port without resetting the entire pic?
Ringo
Ringo Davis
PostPosted: Sat Aug 09, 2008 3:12 pm     Reply with quote
If I2C_ISR_STATE, returns '0x80', then the slave has _received_ the address byte, from the master saying 'I want to read'.
Basically, for the master writing, the first time through, the state will be '0', corresponding to the I2C address byte saying 'I want to write' this results in a read, and nothing else. Then the next time, the state will be '1', which results in the read byte being stored as the internal address to talk to. Then a '2', results in the data being transferred to this address.
For the reading, state 0, says 'I want to read', but still needs to the address byte to be read from the input register. Then after this is read, the new byte wanted has to be read from the local memory, and written to the register, ready for the master to read it.
As shown, the code example is only capable of handling a single byte, not allowing automatic incrementing for states 81, 82 etc..
I2C_ISR_STATE      Byte to be read     Byte to be written
0                           Yes                      No
1                           Yes - I2C Address No
2                           Yes - data             No
3                           Yes - data             No
0x80                      Yes - I2C Address  Yes
0x81                      No                        Yes
The code takes advantage of the first part to automatically perform the reads for state 0, and 80, but just ignores the data read.
Ringo42
PostPosted: Mon Aug 11, 2008 1:06 pm     Reply with quote
I found this post on resetting the I2C port. I'm gonna put this code in place just in case.
http://www.ccsinfo.com/forum/viewtopic.php?t=34634
Ringo
Ringo Davis
