Edstroyer Guest
| turning off BRA when calling a function |
Posted: Wed Aug 06, 2008 7:41 pm |
Basically CCS uses BRA instruction to execute functions (sometimes) to save the stack space usage. Then branches back when function is returned.
However, I'm developing my own pre-emptive RTOS, and I want the compiler to always use RCALL instead of BRA. That way I can manage the stack correctly.
Can i disable this feature of the compiler for PIC18 ?
I used the #separate, but it doesnt solve the problem.
Thanks in advance! |
Posted: Wed Aug 06, 2008 9:02 pm |
You could trick the compiler by using a 2nd call the function, but place
the 2nd call after an infinite loop so that it's never actually reached.
The following program will use RCALL to call func():
| Code: | #include <18F452.h>
#fuses XT,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
void func(void)
char c;
c = 0x55;
func();
func(); // This dummy call is never executed
Edstroyer Guest
Posted: Thu Aug 07, 2008 3:54 pm |
Thank you, thats exactly what I did when i noticed that functions that where called multiple times used RCALL instead so I inserted a second dummy call for all my tasks (at the end of program) and it worked, but I thought it would be unprofessional to do something like that... I was hoping for a feature option that would turn it off.
Thanks anyways, your great PCM PROG!
Ed |
RLScott
| Re: turning off BRA when calling a function |
Posted: Fri Aug 08, 2008 4:54 am |
| Edstroyer wrote: | Basically CCS uses BRA instruction to execute functions (sometimes) to save the stack space usage. Then branches back when function is returned.
However, I'm developing my own pre-emptive RTOS, and I want the compiler to always use RCALL instead of BRA. That way I can manage the stack correctly.... |
I fail to see why using the BRA instruction for entering and leaving a function that is only called from one place in the code is any threat to your pre-emptive RTOS. _________________ Robert Scott
Real-Time Specialties
Embedded Systems Consulting |
