turning off BRA when calling a function
Edstroyer
PostPosted: Wed Aug 06, 2008 7:41 pm     Reply with quote
Basically CCS uses BRA instruction to execute functions (sometimes) to save the stack space usage. Then branches back when function is returned.
However, I'm developing my own pre-emptive RTOS, and I want the compiler to always use RCALL instead of BRA. That way I can manage the stack correctly.
Can i disable this feature of the compiler for PIC18 ?
I used the #separate, but it doesnt solve the problem.
Thanks in advance!
PostPosted: Wed Aug 06, 2008 9:02 pm     Reply with quote
You could trick the compiler by using a 2nd call the function, but place
the 2nd call after an infinite loop so that it's never actually reached.
The following program will use RCALL to call func():
#include <18F452.h>
#fuses XT,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
void func(void)
char c;
c = 0x55;
func();
func();   // This dummy call is never executed
Edstroyer
PostPosted: Thu Aug 07, 2008 3:54 pm     Reply with quote
Thank you, thats exactly what I did when i noticed that functions that where called multiple times used RCALL instead so I inserted a second dummy call for all my tasks (at the end of program) and it worked, but I thought it would be unprofessional to do something like that... I was hoping for a feature option that would turn it off.
Thanks anyways, your great PCM PROG!
Ed
RLScott
Re: turning off BRA when calling a function
PostPosted: Fri Aug 08, 2008 4:54 am     Reply with quote
However, I'm developing my own pre-emptive RTOS, and I want the compiler to always use RCALL instead of BRA. That way I can manage the stack correctly....
I fail to see why using the BRA instruction for entering and leaving a function that is only called from one place in the code is any threat to your pre-emptive RTOS.
Robert Scott
Real-Time Specialties
Embedded Systems Consulting
