help Guest
help interrupts on change... |
Posted: Fri Aug 08, 2008 2:17 am |
hi, my interrupts on change cant work, temp is always is zero...
input for
#define X_IN input(pin_b5)
#define Y_IN input(pin_b6)
is PWM, how to get it work?
Code: | #include <16F917.h>
#device adc=8
#FUSES NOWDT //Watch Dog Timer
#FUSES PROTECT //Code protected from reads
#FUSES NOFCMEN //Fail-safe clock monitor disabled
#use fast_io (B)
#define LCD_ON
#define OUT_LED PIN_B3
#ZERO_RAM
INT1 start=0;
int8 cnt=0;
int16 temp=0,X_VAR=0,Y_VAR=0;
#int_RB
RB_isr()
temp=get_timer1(); clear_interrupt(int_RB);
#include "LCD1.c"
setup_adc(ADC_OFF);
setup_spi(FALSE);
setup_lcd(LCD_DISABLED);
setup_timer_0(RTCC_INTERNAL);//setup_wdt(WDT_DIV_512);
setup_vref(FALSE);
set_tris_b (0b11110111);
enable_interrupts(GLOBAL);enable_interrupts(INT_RB);
setup_oscillator(OSC_4MHZ);
set_tris_a (0xff);
output_high(OUT_LED);
output_low(OUT_LED);
lcd_gotoxy(1,1);
printf(lcd_putc,"A sensor ");
restart_wdt();
cnt++;
lcd_gotoxy(1,1);
Printf(lcd_putc,"GX=%lu T=%lu ",X_VAR,temp);
lcd_gotoxy(1,2);
printf(lcd_putc,"GY=%lu C=%u ",Y_VAR,cnt);
}//while
}//main |
