Willie Erasmus Guest
Shift_left, shift_right, rotate_left, rotate_right |
Posted: Wed Apr 02, 2003 3:31 am |
<font face="Courier New" size=-1>Hi
The CCS compiler help file says that it must be specified in these built-in functions how many bytes must be shifted or rotated. For example: shift_left(address, bytes, value). Is it possible to output any number of bits other than the 8 bits in one byte or must we stick to a "byte(s)"
Willie
</font>
Original Post ID: 13305 |
Neutone
Re: Shift_left, shift_right, rotate_left, rotate_right |
Posted: Wed Apr 02, 2003 8:53 am |
:=<font face="Courier New" size=-1>Hi
:=The CCS compiler help file says that it must be specified in these built-in functions how many bytes must be shifted or rotated. For example: shift_left(address, bytes, value). Is it possible to output any number of bits other than the 8 bits in one byte or must we stick to a "byte(s)"
:=Thanks
:=Willie
:=</font>
The shift functions works like a multiply or divide by 2. This requires you to specify the the size of the number you wish to perform this function on.
Original Post ID: 13309 |
Sherpa Doug Guest
Posted: Wed Apr 02, 2003 9:54 am |
<font face="Courier New" size=-1>:=<font face="Courier New" size=-1>Hi
:=Thanks
:=Willie
:=</font>
The functions all shift by one bit, "value" is a boolean. If you want it to shift a multi-byte word by one bit you must tell it how wide your word is. If you want to shift by several bits you call the function several times.
Does that help?
</font>
Original Post ID: 13310 |
Posted: Thu Apr 03, 2003 1:03 am |
Thanks for your replies
If I want to shift out 6 bits, would the function look like this: shift_left(PIN_B0,1,data) (data can be anything described by 6 bits). I now only put the shift function in a for-loop calling it 6 times?
Willie
:=Thanks
:=Willie
:=</font>
Original Post ID: 13339 |
Sherpa Doug Guest
Posted: Thu Apr 03, 2003 7:52 am |
:=Thanks for your replies
:=If I want to shift out 6 bits, would the function look like this: shift_left(PIN_B0,1,data) (data can be anything described by 6 bits). I now only put the shift function in a for-loop calling it 6 times?
:=Thanks
:=Willie
If you want to shift out a serial stream try something like:
for(i=0;i<6;i++){
output_bit(PIN_B0,shift_left(&data,1,0));
[wait for length of bit]
Which should shift out 6 bits from the byte "data" to pin B0. Note that the output bit of shift_left is its returned value. On the other end of the data 0's are shifted in.
Original Post ID: 13352 |
