Picdem (18f4550) USB HID Help
lifethief
PostPosted: Wed Aug 06, 2008 7:53 am     Reply with quote
I am having an issues using the CCS USB with the pic and demo board. We have a test oven that output UART character data. However the ovens output is continuous. I need to have the pic (w eeprom) log this data at set intervals. I'm trying to use HID. I can get the PC to send data of any amount (tried 2 to 40 bytes) to the Pic but can't get the Pic to return more than 3 byte to the PC. I need to get 100, 40 to 80 character string from the pic to PC. Any help or guidance would be appropriated.
mylog.h
#include <18F4550.h>
//Set A/D converter to 8-bits
#device adc=8
//Setup main
#FUSES HSPLL
#FUSES NOWDT                     //No Watch Dog Timer
#FUSES NOPROTECT                 //Code not protected from reading
#FUSES NODEBUG                   //No Debug mode for ICD
#FUSES NOLVP                     //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES PLL5                      //Divide By 5
#FUSES CPUDIV1                   //System Clock by 1
#FUSES USBDIV                    //USB clock source comes from PLL divide by 2
#FUSES VREGEN                    //USB voltage regulator enabled
#use delay(clock=48000000)
#define __USB_PIC_PERIF__ 1
//Tells the CCS PIC USB firmware to include HID handling code.
#DEFINE USB_HID_DEVICE  TRUE
//the following defines needed for the CCS USB PIC driver to enable the TX endpoint 1
// and allocate buffer space on the peripheral
#define USB_EP1_TX_ENABLE  USB_ENABLE_INTERRUPT   //turn on EP1 for IN bulk/interrupt transfers
#define USB_EP1_TX_SIZE    64  //allocate 64 bytes in the hardware for transmission
//the following defines needed for the CCS USB PIC driver to enable the RX endpoint 1
#define USB_EP1_RX_ENABLE  USB_ENABLE_INTERRUPT   //turn on EP1 for OUT bulk/interrupt transfers
#define USB_EP1_RX_SIZE    64  //allocate 3 bytes in the hardware for reception
#define USB_CON_SENSE_PIN PIN_A1
#include <pic18_usb.h>   //Microchip 18Fxx5x hardware layer for usb.c
#include "my_desc_hid.h"    //USB Configuration and Device descriptors for this UBS device
#include <usb.c>        //handles usb setup tokens and get descriptor reports
my_desc_hid.h
 const char USB_CLASS_SPECIFIC_DESC[] = {
      6, 0, 255,    // Usage Page = Vendor Defined
      9, 1,            // Usage = IO device
      0xa1, 1,       // Collection = Application
      0x19, 1,        // Usage minimum
      0x29, 800,        // Usage maximum =8
      0x15, 0x00,        // Logical minimum (-128) 0x80
      0x25, 0xFF,        // Logical maximum (127) 0x7F
      0x75, 8,        // Report size = 8 (bits)
      0x95, 64,        // Report count = 16 bits (2 bytes)
      0x81, 2,        // Input (Data, Var, Abs)
      0x29, 8,        // Usage maximum
      0x91, 2,        // Output (Data, Var, Abs)
      0xc0            // End Collection
main code
MAX_OUT = 80;
WHILE (TRUE)
   BlinkLED();
       usb_task();
       usb_debug_task();
       IF (usb_enumerated())
           IF(sendoutput == 1)
                sendoutput = 0;
                delay_ms(250); //kjhtlhl
                usb_puts(1, out_data, MAX_OUT, 250);
           IF (usb_kbhit(1))
               usb_gets(1, in_data, MAX_IN, 250);
               printf("Recived 0x%X\n",in_data[0]);
               if(in_data[0] == 1)
                sendoutput = 1;
               else if(in_data[0] == 4)
                write_eeprom(0, in_data[1]);
           delay_ms(1);
at this point I just want to get this simple code working. Im using the USB HID Device Library on the PC (http://labs.mike-obrien.net/view.aspx?projectid=hidlibrary) and since I can write data to the pic and can read 3 byte I know it is the pic code.
