One wire Search Rom problem can't read the code
psypersky
PostPosted: Mon Aug 04, 2008 4:21 pm     Reply with quote
Hi, I'm trying to make work a DS18S20. I'm using the onewire.c and ds1820.c libraries, but I have a problem with the Search ROM command, the program send it, and when reads the first two bits, only read "1" and "1" ... :S Which means that there aren't a sensor connected, or no response.
I have my 4.7K pull up resitor, and is in normal mode.
The functions reset() and search_supply() works fine,
Does anyone have an idea why this happens?
  flag = ow_reset(); // igual a 1 si no hay dispositivos .. =1 if no devices
   if (flag||doneFlag)     // If no parts return false y no estamos en first()...
      lastDiscrep = 0;     // Reset the search
      return FALSE;
   write_byte(0xF0);       // Send SearchROM command
   do
      x = 0;
      if (read_bit() == 1) x = 2;
     delay_us(120);
      if (read_bit() == 1) x |= 1;   // And it's complement
    printf(lcd_putc,"\fFOUND %u",x);
  //delay_ms(5000);
      if (x == 3)                   // There are no devices on the one wire bus
PostPosted: Mon Aug 04, 2008 4:40 pm     Reply with quote
Don't start a new thread with the same question.
A few days ago you asked exactly the same question in http://www.ccsinfo.com/forum/viewtopic.php?p=102076.
Two people gave you suggestions. You didn't respond. Were these suggestions not helpful?
Please post all responses in the original thread.
psypersky
PostPosted: Mon Aug 04, 2008 10:13 pm     Reply with quote
It wasn't helpful cause I did a too large post and too much code, and nobody wanted to read the entire post, so I make a short post of my question.
