how to read data from RAM
abawan
PostPosted: Tue Aug 05, 2008 2:42 am     Reply with quote
Hi Smile
i want to know the command to access data in RAM of pic16f877a. as i use MOVC A,@+DPTR for 8051, how can i use it in pic.
i am using CCS compilar.
thanks
PostPosted: Tue Aug 05, 2008 3:12 am     Reply with quote
Stop thinking in assembler. You are using C now. All your variables are in RAM. If you want to access a particular location, either use the #byte directive, or #locate, to put a C variable at the required location.
However much better to just let C handle the memory for you.
If you want to work relative to a 'pointer', then use the C pointer access, or array access.
