volcane
Reset RCREG |
Posted: Fri Apr 24, 2009 2:00 pm |
Hi!
You can reset RCREG directly? or the system is this:
Code: | while(kbhit())
printf("the character is:%c", getc());
volcane
Posted: Fri Apr 24, 2009 3:33 pm |
hi!
if i use the program crashes, i think it is a problem with the USART:
Code: | #byte RCREG = 0x1A
void clear_usart_receiver(void)
char c;
c = RCREG;
c = RCREG;
c = RCREG;
if I use this I have no crashes:
Code: | void clear_usart(void)
char c;
c = getc();
c = getc();
c = getc();
Posted: Fri Apr 24, 2009 3:52 pm |
Post your PIC. |
volcane
Posted: Fri Apr 24, 2009 5:33 pm |
Hi!
PCM programmer wrote: | Post your PIC. |
with this work:
Code: | #include <16F877a.h>
#include <apricancello_gsm.h>
#include <string.h>
#include <input.c>
#byte RCREG = 0x1A
#define STRING_SIZE 51 // The number of characters allowed to input
char c;
c = getc();
c = getc();
c = getc();
void tipo_chiamata(char *chiamata)//, char *prima)
delay_ms (1000);
output_low (red_led);
printf("\n\nil valore di chiamata e' %s\n\n", chiamata);
delay_ms (1000);
output_high (red_led);
delay_ms (1000);
clear_usart();
void inizializza()
printf("at+ipr=9600\r");
delay_ms(2000);
printf("at+clip=1\r");
printf("ate0\r");
delay_ms(2000);
clear_usart();
void main() {
int a;
char input_str[STRING_SIZE];
inizializza();
while(true)
for (a=0; a<4; a++)
get_string(input_str,STRING_SIZE); // gets the string x4
printf("ath\r");
tipo_chiamata(input_str);
This does not work:
char c;
c = RCREG;
c = RCREG;
c = RCREG;
Posted: Fri Apr 24, 2009 5:42 pm |
The RCREG version immediately clears the UART receiver and returns.
This routine takes only maybe 2us to execute, with a 20 MHz crystal.
Your getc() version waits for the first 3 characters to arrive in the UART
and throws them away. It could wait forever, if there are no characters
in the UART, or if less than 3 characters arrive.
I don't really know what the purpose of your code is. |
Posted: Sat Apr 25, 2009 2:21 am |
The 'safe' way to ue the standard getc, to clear the UART, is:
void clear_usart(void) {
char c;
while (kbhit()) c=getc();
This will read any characters waiting in the hardware buffer, but unlike the three successive reads, won't hang if charcaters are not available.
Just reading RCREG three times, will generate much more compact code, and do the same job.
