		| Author | Message |
		| andyhug
				| Interface PIC16F877-DS1620 |
				|  Posted: Fri Jul 25, 2008 9:09 am |   |
				| Can some one check my code, help me how to write TH, TL limit temperature register?
 I use Proteus7.2 SP2 to simulation, CCSC 4.049 to compile. I tried to write TH, TL but when I download to chip it didn't worked! It only displayed temperature. 	  | Code: |  	  | //*--------------------------------------------------------------------------------- //* writer           : Pham Thanh Cong
 //* Date             : 18/06/2008
 //* to date           : 22/07/2008
 //* Hardware      : PIC16F877A, LCD 2x16[5x7] LMB162A, DS1620
 //* Program       : use DS1620 and display temperature on LCD LMB162A
 #include <16F877A.h>
 #include <stdlib.h>
 #include <string.h>
 #fuses XT,NOWDT,NOPROTECT,NOLVP  // set config for PIC
 #use fast_io(A)                  // use with comand set_tris
 #use fast_io(B)
 #use fast_io(D)
 #byte   PORTB    = 0x06    // PortB address
 #define LCD PORTB
 #bit RA2         = 0x05.2
 #bit RA1         = 0x05.1
 #bit RA0         = 0x05.0
 #define RS  RA0                // RS =0 comand,RST =1 Data
 #define RW  RA1               // RW=1 read, RW =0 write
 #define E   RA2                 // H-to-L enable LCD
 #bit RD1         = 0x08.1     // data pin's DS1620
 #bit RD2         = 0x08.2     // clock pin
 #bit RD3         = 0x08.3     // reset pin
 #define DQ     RD1            // =0 output, =1 input
 #define CLK    RD2
 #define RST    RD3
 // Functions used in program
 void LCD_init(void);
 void comandwrt(void);
 void datawrt(void);
 void LCD_gotoxy(byte x, byte y);
 void DS1620_InitTemp(void);
 unsigned int8 DS1620_GetTemp(void);
 void DS1620_Write(unsigned char Data);
 unsigned int8 DS1620_Read(void);
 void display(int8 temp);
 void main(void);
 // Global variable
 const unsigned char dongchu[]="Temp:";      // global const
 int i = 0, sign = 0;                                      //
 //xxxxxxxxxxxxxxxxxxxxxxxx LCD Program xxxxxxxxxxxxxxxxxxxxxxx
 void LCD_init()
 delay_ms(50);       // delay at least 30ms
 LCD = 0x38;         // 2line, dot matrix 5*8, 8 bits interface
 comandwrt();
 delay_us(50);       // delay at least 39us
 LCD = 0x0C;         // display on, cusor off and blink off
 comandwrt();
 LCD = 0x01;         // clear display
 comandwrt();
 delay_ms(3);        // delay at least 1.53ms
 LCD = 0x06;         // increase cusor
 comandwrt();        // and blink off
 delay_ms(1);
 // Function send comand to LCD
 RS = 0;
 RW = 0;
 E  = 1;
 E  = 0;
 delay_ms(1);
 // Function send data to LCD
 void datawrt(void)
 RS = 1;
 RW = 0;
 E  = 1;
 E  = 0;
 delay_ms(1);
 // Function move pointer xy(colum,line) on LCD display
 void LCD_gotoxy(int x, int y)
 {  int address;
 switch(y)
 case 1:  address=0;
 address+=x-1;
 LCD = (0x80 + address);    // line 1, colum1: 80h
 case 2:  address=0;
 address+=x-1;
 LCD = (0xC0 + address);    // line 2, colum1: C0h
 default : break;
 //xxxxxxxxxxxxxxxxxxxxxxx DS1620 Program xxxxxxxxxxxxxxxxxxxxx
 RST = 1;                       // setup 3-wire mode.
 DS1620_Write(0x0C);    // enable write config
 DS1620_Write(0x00);    // clear config, setup continuous [spam]
 RST = 0;
 DS1620_Write(0xEE);    // start [spam]
 RST =0;
 unsigned char i;
 set_tris_D(0);             // Port D : ouput
 CLK = 1;                    // set clock pulse
 for (i=1; i<=8; ++i)
 DQ = (Data & 1);
 CLK = 0;
 Data = Data >> 1;  // shift Data
 unsigned int8 Data, temp;
 set_tris_D(0x02);            // DQ = 1 input, others: ouput
 Data = 0;
 temp = 1;
 CLK = 1;
 CLK = 0;                     // CLK = 0: convert
 if (DQ == 1) Data += Temp;
 Temp = Temp << 1;
 CLK = 1;
 CLK = 0;
 if (DQ == 1) Sign = 1;      // get sign bit, the 9th bit
 else Sign = 0;
 CLK = 1;
 return(Data);
 unsigned int8 Data;
 RST =1;
 DS1620_Write(0xAA);       // enable read temperature
 data = DS1620_Read();    // read temp
 RST =0;                          // end 3wire mode
 return(data);
 int8 Data, leng;
 unsigned char string[3];
 if (sign == 1)                        // minus degree
 LCD_gotoxy(5,2);
 comandwrt();
 LCD = '-';
 datawrt();
 Data = ~(temp - 1) / 2;
 else  {  LCD_gotoxy(5,2);      // positive
 comandwrt();
 LCD = '+';
 datawrt();
 Data = temp / 2;
 itoa(Data,10,string);
 leng = strlen(string);
 if (bit_test(temp,0))
 for(i=0;i<leng;i++)
 LCD = string[i];               // put temp
 datawrt();
 LCD = '.';
 datawrt();
 LCD = '5';
 datawrt();
 LCD = ' ';
 datawrt();
 LCD = 'd';
 datawrt();
 LCD = 'o';
 datawrt();
 LCD = 'C';
 datawrt();
 for(i=0;i<leng;i++)
 LCD = string[i];
 datawrt();
 LCD = '.';
 datawrt();
 LCD = '0';
 datawrt();
 LCD = ' ';
 datawrt();
 LCD = 'd';
 datawrt();
 LCD = 'o';
 datawrt();
 LCD = 'C';
 datawrt();
 //xxxxxxxxxxxxxxxxxxxxxxxx Main function xxxxxxxxxxxxxxxxxxxxxxx/
 int8 data;
 set_tris_B(0);                       // output
 set_tris_A(0);                       // output
 LCD_init();                           // set LCD mode
 delay_us(2);
 DS1620_InitTemp();
 delay_ms(2);
 LCD_gotoxy(5,1);                 // colum 5, line 1
 comandwrt();
 for (i=0;i<=8;i++)
 LCD = dongchu[i];             // put line words to LCD
 datawrt();
 data  = DS1620_GetTemp();     // get data
 display(data);
   Can some one give me answer?
 My email: phamthanhcongd12@yahoo.com
 Thanhks alot!
 Khong co gi qui hon doc lap tu do!
 xxxxxxxxx Ho Chi Minh xxxxxxxx
		| andyhug
				| Final I did it! Yahoo! |
				|  Posted: Fri Jul 25, 2008 12:32 pm |   |
				| //*-------------------------------------------------------------------------------- //* Tac gia              : Pham Thanh Cong
 //* Ngay viet           : 18/06/2008
 //* Ngay hoan thanh: 21/07/2008
 //* Phan cung          : PIC16F877, LCD 2x16[5x7]
 //* Chuong trinh     : do nhiet do dung DS1620 hien thi tren LCD LMB162A
 // Khoi tien xu ly
 #include <stdlib.h>
 #include <string.h>
 #fuses XT,NOWDT,NOPROTECT,NOLVP  // dat cau hinh cho PIC
 #use fast_io(A)                  // su dung cung voi lenh set_tris
 #use fast_io(B)
 #use fast_io(D)
 #byte   PORTB    = 0x06
 #define LCD PORTB
 #bit RA2         = 0x05.2
 #bit RA1         = 0x05.1
 #bit RA0         = 0x05.0
 #define RS  RA0               // chan chon thanh ghi =0 lenh hay =1 du lieu
 #define RW  RA1               // =1 doc hay =0 ghi
 #define E   RA2               // H-to-L de cho fep LCD
 #bit RD1         = 0x08.1     // chan data cua DS1620
 #bit RD2         = 0x08.2     // chan dong ho
 #define CLK    RD2
 #define RST    RD3
 // khai bao cac ham su dung trong chuong trinh
 void datawrt(void);
 void DS1620_WriteTHTL(unsigned char Data, int dau);
 void main(void);
 // Cac bien toan cuc
 const unsigned char dongchu[]="Nhiet do:";      // Hang so toan cuc
 int i = 0, Sign = 0;                            // Bien toan cuc
 //xxxxxxxxxxxxxxxxxxxxxxx Program LCDxxxxxxxxxxxxxxxxxxxxxxxx
 // Khoi tao cho LCD
 void LCD_init()
 delay_ms(50);       // tre it nhat 30ms
 LCD = 0x38;         // Hai hang, ma tran diem 5*8, 8 bit interface
 comandwrt();
 delay_us(50);       // tre it nhat 39us
 LCD = 0x0C;         // bat hien thi, tat con tro va tat nhap nhay
 comandwrt();
 LCD = 0x01;         // xoa man hinh
 comandwrt();
 delay_ms(3);        // tre it nhat 1.53ms
 LCD = 0x06;         // che do tang con tro sau khi viet 1 ki tu
 comandwrt();        // va chu khong chay
 delay_ms(1);
 // Ham gui lenh ra LCD
 RS = 0;
 RW = 0;
 E  = 1;
 E  = 0;
 delay_ms(1);
 // Ham gui du lieu ra LCD
 void datawrt(void)
 RS = 1;
 RW = 0;
 E  = 1;
 E  = 0;
 delay_ms(1);
 // Ham di chuyen con tro toi vi tri xy(cot,hang) tren man hinh LCD
 {  int address;
 switch(y)
 case 1:  address=0;
 address+=x-1;
 LCD = (0x80 + address);    // dong 1, cot1: 80h
 case 2:  address=0;
 address+=x-1;
 LCD = (0xC0 + address);    // dong 2, cot1: C0h
 default : break;
 //xxxxxxxxxxxxxxxxxxxxx Program DS1620 xxxxxxxxxxxxxxxxxxxxxxx
 // Khoi tao DS1620
 RST = 1;               // thiet lap che do giao tiep 3-wire.
 DS1620_Write(0x0C);    // cho phep ghi config
 DS1620_Write(0x08);
 RST = 0;
 DS1620_Write(0xEE);    // bat dau chuyen doi nhiet do
 RST = 0;
 set_tris_D(0);           // cong D la cong ra
 CLK = 1;                 // tao clock
 DQ = (Data & 1);    // viet bit thap len DQ
 CLK = 0;
 Data = Data >> 1;   // dich fai Data di 1 bit
 CLK = 0;
 CLK = 1;
 if (dau == 1) DQ = 1; // Lay gia tri bit dau, gui not bit9 di
 else          DQ = 0;
 CLK = 0;
 set_tris_D(0x02);       // Chan DQ = 1 : chan vao, con lai la chan ra
 Data = 0;
 temp = 1;
 CLK = 1;
 if (DQ == 1) Data += Temp; //neu DQ = 1, cong don Data
 Temp = Temp << 1;        // neu DQ = 0, dich trai temp 1bit de chen 0 vao
 CLK = 1;
 CLK = 0;
 if (DQ == 1) Sign = 1;// Lay gia tri bit dau
 else Sign = 0;
 CLK = 1;
 return(Data);
 unsigned int8 Data;
 RST =1;                  // thiet lap che do giao tiep 3-wire
 DS1620_Write(0xAA);      // lenh cho phep doc noi dung thanh ghi nhiet
 data = DS1620_Read();    // doc noi dung
 RST =0;                  // ket thuc che do giao tiep 3-wire
 return(data);
 int8 Data, leng;
 if (sign == 1)                // Nhiet do am
 LCD_gotoxy(5,2);
 comandwrt();
 LCD = '-';                 // Hien thi dau -
 datawrt();
 Data = ~(temp - 1) / 2;    // neu nhiet do am thi lay ma bu 2
 else  {  LCD_gotoxy(5,2);     // Nhiet do duong
 comandwrt();
 LCD = '+';           // Hien thi dau +
 datawrt();
 Data = temp / 2;
 itoa(Data,10,string);         // Chuyen doi Data thanh ma ASCII vao string
 leng = strlen(string);        // Lay chieu dai cua string
 if (bit_test(temp,0))         // kiem tra bit0 =1 suy ra nhiet do .5 doC
 for(i=0;i<leng;i++)
 LCD = string[i]; // xuat nhiet do ra o dang ki tu so
 datawrt();
 LCD = '.';          // hien thi phan thap phan .5 do C
 datawrt();
 LCD = '5';
 datawrt();
 LCD = ' ';
 datawrt();
 LCD = 'd';
 datawrt();
 LCD = 'o';
 datawrt();
 LCD = 'C';
 datawrt();
 else                   // bit0 =0 suy ra nhiet do .0 do C
 for(i=0;i<leng;i++)
 datawrt();
 LCD = '.';          // hien thi phan thap phan .0 do C
 datawrt();
 LCD = '0';
 datawrt();
 LCD = ' ';
 datawrt();
 LCD = 'd';
 datawrt();
 LCD = 'o';
 datawrt();
 LCD = 'C';
 datawrt();
 //xxxxxxxxxxxxxxxxxxxxxxx Ham main xxxxxxxxxxxxxxxxxxxxxxxxx*/
 int8 data;
 set_tris_B(0);                   // cong ra
 set_tris_A(0);                   // cong ra
 LCD_init();                      // dat che do hoat dong cho LCD
 delay_us(2);
 DS1620_InitTemp();               // dat che do hoat dong cho DS1620
 delay_us(10);
 LCD_gotoxy(5,1);                 // Vi tri cot 5, hang 1
 comandwrt();
 for (i=0;i<=8;i++)
 LCD = dongchu[i];             // xuat chu ra LCD
 datawrt();
 RST = 1;
 DS1620_Write(0x01);           // write TH
 DS1620_WriteTHTL(0x44,0); // TH = +34 do C
 DS1620_Write(0x00);    // infact must have this comand to  'run ok'
 RST = 0;
 RST = 1; // infact must put this comand in to this loop to 'run ok'
 DS1620_Write(0x02);              // write TL
 DS1620_WriteTHTL(0x40,0);    // TL = +32 do C
 DS1620_Write(0x00);
 RST = 0;
 display(data);                         // display data
 | You cannot post new topics in this forum You cannot reply to topics in this forum
