jman Guest
typedef enum |
Posted: Tue Jul 22, 2008 3:53 pm |
If I have the following:
typedef enum{
A,
B,
C
} ALGORITHM_STATE;
How do I declare the variable “state” of the above typedef in the main program? |
Posted: Tue Jul 22, 2008 6:01 pm |
The answer, as always, is to make a test program. Probably you have
some idea of how to do it. Make a test program and see if your idea is
correct. Example:
#include <16F877.H>
#fuses XT,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
#use delay (clock=4000000)
typedef enum{
A,
B,
C
}ALGORITHM_STATE;
ALGORITHM_STATE state;
state = A;
printf("%u ", state);
state = B;
state = C;
Here's the output when run in MPLAB simulator:
jman Guest
typedef enum |
Posted: Wed Jul 23, 2008 7:34 am |
I tried to declare "state" using the following:
Then, I coded:
state = A;
When I compiled, I got an error. The IDE tells me it expects a variable in the line where I declare "state." |
meereck
Posted: Wed Jul 23, 2008 1:13 pm |
did you run PCM Programmer's test program at all?
Does it work for you? |
Posted: Wed Jul 23, 2008 1:31 pm |
And also, post your compiler version. |
