atomy_kwang
| How to shift left string on lcd module |
Posted: Sat Jul 19, 2008 8:38 am |
| Code: | #include <16f877a.h>
#fuses hs,nolvp,nowdt,noprotect
#use delay(clock = 20000000)
#use fast_io(B)
#define use_portb_lcd
#include <lcd.c>
#define maxchar 16
char buff[maxchar] = "batman " ;
char c;
int i;
void rotate_string(void)
c = buff[0];
for(i=0;i<maxchar-1;i++)
buff[i] = buff[i+1];
buff[maxchar-1] = c;
void display_string(void)
printf(lcd_putc," %c ", buff[i] );
set_tris_b(0x00);
lcd_init();
while(true)
display_string();
rotate_string();
this is my code , but i think it is wrong , please help me
ps. i want to shift left string all time on lcd module in the 2 line of lcd
but my code it cannot shift left because a new character is occur in the
same position as old character
ps. in the 1 line of lcd i would like to show another string on the middle of
lcd i can us command :
lcd_gotoxy( , );
ps. i cannot use command 0x07 (shift left) because it shift my string
in the 1 and 2 line of lcd
who know about this , Help me please.
Thank you very much |
Posted: Sat Jul 19, 2008 5:13 pm |
The rotate_string() function looks OK to me.
The display_String () function however is wrong: | Code: | | printf(lcd_putc," %c ", buff[i] ); | This will print: a space, a single random character, and a space.
The printed character is more or less random because when you execute this line the global variable 'i' is at value maxchar and buf[maxchar] is outside of the array.
try: | Code: | void display_string(void)
lcd_gotoxy(1,2); // move to first position of line 2
lcd_putc( buff[i] );
Another problem: | Code: | #define maxchar 16
char buff[maxchar] = "batman " ; | The string contains only 14 characters + a terminating zero = 15.
Ther terminating zero is not readable text and might give strange results on your display. Fix by adding an extra space character to your string. |
atomy_kwang
Posted: Sat Jul 19, 2008 11:07 pm |
| thank you very much for edit code , i can do it successfully |
