pins as a function's parameter
mutevaggil
PostPosted: Wed Jul 16, 2008 1:21 am     Reply with quote
hi, i want to use a pin as a function parameter. How can i pre-define it in .h file ?
void sample_func (byte) ?
I know i can write the address number of pin, but my parameter is a variable pin. I mean it is code like this:
x=sample_func(pin_c0);
y= sample_func(pin_c1);
As you see, functions are the same, but pins are different. My function:
sample_function( ?! dumper_pin)
if (dumper_pin==pin_c1) ...
if (dumper_pin==pin_c0) ...
PostPosted: Wed Jul 16, 2008 10:06 am     Reply with quote
The pin constants are given in the .H file for your PIC. The .H files are
in this directory:
c:\Program Files\Picc\Devices
If the PIC is a 16F, the data type for the pin constant will be 'int8'.
If the PIC is 18F, it will be 'int16'.
Also, the C style is to use upper case for constants. Example: PIN_C0
