javi.ar
GLCD 128x64 flickers |
Posted: Sat Jul 05, 2008 4:33 pm |
Hi I have a glcd 128x64 with this fuses
#include <18F4525.h>
#device ICD=TRUE
#device adc=8
#FUSES H4 //High speed osc with HW enabled 4X PLL
#FUSES BORV21 //Brownout reset at 2.1V
#FUSES PUT //No Power Up Timer
#FUSES LVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES NOFCMEN //Fail-safe clock monitor enabled
#FUSES NOXINST //Extended set extension and Indexed Addressing mode enabled
#FUSES NOPBADEN //PORTB pins are configured as analog input channels on RESET
#FUSES NOMCLR //Master Clear pin enabled
#use delay(clock=40000000)
#use rs232(baud=19200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,errors) |
and the output on the screen flickers .
But with this changes
#FUSES HS
#use delay(clock=10000000)
stops flickering but I cannot get RS232 communication
CCS VER 4.068
I am using original HDM64GS12.c file. with the FAST_GLCD option defined.
The question is why is this behaviour? Thanks a lot |
Posted: Sun Jul 06, 2008 3:00 pm |
The serial should work in both cases. What is your crystal?.
Have you removed the 'H4' fuse?.
If not, the system will still be running at 40Mhz, but the UART timings will be set based upon a 10Mhz rate, which would explain the failure.
My guess, would be that the 'flicker' is actually being caused by your code, not the LCD driver. I'd suspect you have some delay_us, or delay_ms calls in your own code, leading to the flickering. If the H4 fuse is still present, these are being executed 4* faster, and the flickering disappears.
The LCD code itself, does not use the delay timings (the only timings used are _cycle_ based delays, which do not use the 'clock' value.
crystal_lattice
Posted: Tue Jul 08, 2008 7:17 am |
The delay_cycles COULD be a problem, if the driver has used a 'pre' calculated delay based on the timing of a cycle, you could encounter problems when changing the crystal.
I've encountered some strange problems with a LCD when changing to faster speed and not adjusting the delay_cycles routines accordingly. Worth looking into... |
