Im using the PIC to read 4 voltages off of a quad photodiode. Is it possible to sample and hold all 4 voltages simultaneously, and then convert them one at a time?
I suspect that Ill need an external quad sample and hold ic, but wondered if this was possible with just a PIC.
SherpaDoug
Posted: Tue Jul 08, 2008 7:27 pm
All the PICs that I am aware of have a MUX feeding a single A/D, so you can not simultaneously sample 4 inputs. You have to select an input, wait a settling time, then read the A/D, then select the next input. _________________ The search for better is endless. Instead simply find very good and get the job done.
