		| Author | Message |
		| smackaay
				| What am I doing wrong? |
				|  Posted: Thu Jul 03, 2008 12:42 pm |   |
				| I'm new to this particular C compiler and I'm curious why I can't seem to reliably compile. Every time I try and compile the following piece of code, it gives me the error "A numeric expression must appear here" when trying to declare a variable. It highlights any variable declaration beyond the mass of initialization functions.
 here's the code
  	  | Code: |  	  | #include "C:\Rotary Viscometer\pcwsource\pwm.h"
 int a;
 setup_adc(ADC_OFF);
 setup_spi(SPI_SS_DISABLED);
 setup_timer_1(T1_DISABLED);
 setup_comparator(NC_NC_NC_NC);// This device COMP currently not supported by the PICWizard
 setup_oscillator(OSC_8MHZ);
 a=1; //Why I hav e to do this??!?!?!?
 int PWMFill;
 while (1)
 As you can see, I'm just playing around so far, but this problem really bugs me. I was able to quell the error when I put the declartion of 'a' at the beginning and place an 'a=1;' afterwards but declaring the variable afterwards still doesn't work.
		| smackaay
				| AAAARGH! it still makes no sense |
				|  Posted: Thu Jul 03, 2008 1:32 pm |   |
				| I've totally removed anything that could cause a problem!!!!
  	  | Code: |  	  | int initialize();
 int a;
 a=initialize();
 int b; //<----Error's here!
 b=1;
 int initialize()
 return 0;
 It still hangs when I declare anything after the function call!!! why!!!?!?!?! it doesn't recognize b as a variable and it says "Error 51, a numeric expression must be placed here" at "int b;"
 I don't understand!!!! what am I doing wrong, if anything. Anyone seen anything like this?
		| PCM programmer
				|  Posted: Thu Jul 03, 2008 1:37 pm |   |
				| Don't put variable declarations in the middle of your code.  Put them at the beginning of your functions, including main().  Then, all your
 problems will go away.
		| smackaay
				|  Posted: Thu Jul 03, 2008 1:39 pm |   |
				| Oh, ok, thanks. kind of a weird rule for C. but cool, thanks! It was the source of a great deal of frustration. |  |
		| Wayne_
				|  Posted: Fri Jul 04, 2008 1:57 am |   |
				| Actually it has always been the case for C to have variable declarations at the start of a block {...}. Only when C++ came along did they allow for declarations to be placed anyware, including within loop declarations:-
 for (int i=0; i<10; i++) {...}
