Need help with this GSM isr please
kavinyang
PostPosted: Wed Jul 02, 2008 9:02 pm     Reply with quote
I know that there are SMS message to be retrieve because
when i first stored a message to it using hyper terminal, by
setting the modem to text mode and sent a text message to the
GSM modem, well the SMS message is stored in the location index number 1
and I'm trying to read from it by using PIC but I'm not getting anything base on my
interrupt.
i set the modem to text mode first by sending:
AT+CMGF =1 ; put modem in text mode ; modem return OK
AT+CMGR =1 ;read at index location 1 on GSM modem ; modem return OK
when I'm reading, i set my isr() to get whatever the modem is returning to the PIC and had it display on LCD
but I'm not getting anything :(
this is my code:
#int_rda
void serial_isr()
output_low(PIN_B5);
char_rcvd = fgetc(GSM);
   while (i != 10)
   data[i]=char_rcvd;
   t=1;
   i++;
   data[i] = 0;            // return new line shows that all character has been collected
   output_low(PIN_B4);
   disable_interrupts(int_rda);
void readindex(void)
  while(1){
      output_high(PIN_B7);
      fprintf(GSM, "AT+CMGF= 1");  //set to text mode
      fprintf(GSM, "\r\n");
      delay_ms(2000);
      output_high(PIN_B6);
      fprintf(GSM, "AT+CMGS= (my number)r\n");   //write text message
      fprintf(GSM, "HELLO WORLD");
      fputc(0x1A,GSM);//CTR+Z to send
      output_low(PIN_B2);
      fprintf(GSM, "AT+CMGR=1");  //Read SMS at location 1
      delay_ms(1);
      enable_interrupts(int_rda);
      delay_ms(2000);
      output_low(PIN_B6);
      output_low(PIN_B7);
      while(t!=1){}    // wait til interrupt
      t = 0;
      cursor_position(0x84);
      out_lcd_string(data);    //send display reading string to LCD
      output_high(PIN_B2);
PHIA YANG
PostPosted: Wed Jul 02, 2008 10:56 pm     Reply with quote
Don't do your isr code like that. It's wrong. You should only get one
character each time the isr is called.
See some of the comments in this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=34648
Also, you need to simplify your program for the first test. Make it shorter.
You should be able to write a short program (maybe 30 lines) that tests
the ability to talk to the GSM.
If you post another program, make sure it's complete. Post the
#include, #fuses, #use delay(), and #use rs232() statements.
Post the main(). The "30 lines of code" includes all these things.
