timer interrupts driving port pins low when inputs
Hadden
PostPosted: Thu Jul 03, 2008 4:38 am     Reply with quote
Hi
i have written a peice of code for PIC16F687 where i am running a timer0 is used as a refresh rate on a segment display.
on PORTA pin 5 i have a switch that uses the internal pull up resistor and is used active low.
for some reason the interrupt of the timer is driving the pin low on the interrupt.
i look at the datasheet and the interrupt of the time and the pin use the same 5th bit but should be in different registers and should not effect each other.
Does anyone have any ideas to what is going on, and is there a way i can just read the registers direct rather than passing a value in to a function.
i tried using a different timer in the PIC but none of them are fast enough to uses with the segment display.
PostPosted: Thu Jul 03, 2008 4:44 am     Reply with quote
What compiler version?.
What are you actually doing in the interrupt?.
The timer0 interrupt, _does not use bit 5 of any register_. It uses bit 2. The only thing using bit 5, for this interrupt, is the 'enable', which once set by you during the startup, is not changed in any way at all by the interrupt.
