Olli Guest
Convert hex to decimal number |
Posted: Mon Mar 31, 2003 8:20 pm |
Hey guys!!
I receive a hex number from the AD converter into the PIC controller and i wonder how to convert it to a decimal. Need program code now...
Olli
Original Post ID: 13271 |
dyeatman
Re: Convert hex to decimal number |
Posted: Mon Mar 31, 2003 9:02 pm |
Olli,
We are not here to write your code for you. Here is a link to a site that outlines how you have to approach the problem code wise:
<a href="http://www.festra.com/wwwboard/messages/1848.html" TARGET="_blank">http://www.festra.com/wwwboard/messages/1848.html</a>
Once you have some code and have taken a shot at it we might be able to help you debug it...
Good Luck,
:=Hey guys!!
:=I receive a hex number from the AD converter into the PIC controller and i wonder how to convert it to a decimal. Need program code now...
:=Olli
Original Post ID: 13274 _________________ Google and Forum Search are some of your best tools!!!! |
Sherpa Doug Guest
Posted: Tue Apr 01, 2003 8:11 am |
:=Hey guys!!
:=Olli
What kind of A/D converter gives a HEX number? There were some built in the 1950's and 1960's that gave BCD output but I would assume you have a BINARY number you want to convert to decimal.
I don't write code for people, but here is the brute force technique I have used for years. Start by subtracting 100's (or 1000's if the input is 12 bit or more) until the result is negative. Drop a factor of ten and start subtracting again until you get to 1's. If the input is 8 bits or less it is not worth looping the code unless it helps readability.
This is real simple stuff and implimentation is left as an exercise for the student.
Original Post ID: 13282 |
John P Guest
Posted: Wed Apr 02, 2003 11:16 am |
:=Olli
Here's a link to code that does what you want, and I can't grumble if you just use it verbatim because I use it myself. But if you want to understand how it works, there are notes attached that explain it.
Note that this is general-purpose code to turn a 16-bit quantity into BCD, so it has a ten-thousands output that the 10-bit A/D won't use. You can just ignore it.
<a href="http://www.dattalo.com/technical/software/pic/bcd.txt" TARGET="_blank">http://www.dattalo.com/technical/software/pic/bcd.txt</a>
Original Post ID: 13317 |
