USB bulk demo driver
Hampton
PostPosted: Mon Jun 30, 2008 2:54 pm     Reply with quote
I'm running through the USB dev kit tutorial and am having trouble with the bulk demo. I installed the driver, but when I try to run the example the device manager gives me the error "This device cannot start. (Code 10)"
I am running Vista. I cannot find any driver updates on the CCS website. Any thoughts?
Hampton
PostPosted: Tue Jul 01, 2008 2:55 pm     Reply with quote
I can't get the virtual com port driver to install either. I get the error "Windows found driver software for your device but encountered an error while attempting to install it.
USB to UART
The system cannot find the file specifi
PostPosted: Tue Jul 01, 2008 3:17 pm     Reply with quote
The virtual comm port should work. There is a latter 'cdc_NTXPVista.inf', which even works on Vista64, that has downloaded with the compilers for a long time now.
Hampton
PostPosted: Tue Jul 01, 2008 3:44 pm     Reply with quote
How do I get vista to install the proper driver? I've found the 'cdc_NTXPVista.inf' driver in the PICC/Drivers folder, but when I try to right click and "install" I am told "the INF file you selected does not support this method of installation." If I go to the device manager and update the driver and point it to the Drivers folder I get the same error as before (cannot find the file specified).
EDIT: nevermind. I had to copy the cdc_NTXPVista.inf file to a new folder with nothing else in it and point the device manager to it. It looks like the device manager was still trying to install the old (non-vista) version because both versions were in the PICC\Devices directory. Vista will only let you point the device manger to a directory and not a specific file. Yay vista!
