butterfly robot
arawana
butterfly robot
PostPosted: Wed Jul 02, 2008 7:12 am     Reply with quote
hello.. below is my code for my butterfly wings.. i use 2 motors and each motor have 2 limit switches...
the motor do not have same speed.. so my sequence is..
first:
both wings go up
then:
if one of the motor touch the limit switch, the motor will stop until the second motor touch the other switch... then both motors will go down... until one of the motor touch limit switch...it will stop and wait the other to touch the limit switch..and other motors go up again... repeat~~
here is my code..
#include "16F877A.h"
#use Delay(Clock=20000000)
#fuses HS, NOWDT, NOPROTECT, PUT, BROWNOUT, NOLVP
////////////////// left wing   ///////////////////
#define UP1 PIN_d2
#define DOWN1 PIN_d3
#define PWM1 PIN_c1 // enb a pin 16
////////////////// right wing ////////////////////
#define UP2 PIN_d0
#define DOWN2 PIN_d1
#define PWM2 PIN_c2 //enb b pin 17
/////////////////// main()  ////////////////////
      output_high(pwm1);
      output_high(pwm2);
      output_high(up1); //CW up
      output_low(down1);
      output_high(up2); //CW up
      output_low(down2);
      output_high(pwm1);
      output_high(pwm2);
      output_low(down1);
      output_low(down2);
     if(!input(PIN_a1)) //limit switch up
          output_high(pwm1);
          output_high(pwm2);
         do
          output_low(pwm1);
          output_high(pwm2);
         while(input(PIN_a3));
          output_high(pwm1);
          output_high(pwm2);
          output_low(up1); //CCW down
          output_high(down1);
          output_low(up2); //CCW down
          output_high(down2);
      if(!input(PIN_a3)) //limit switch up
          output_high(pwm1);
          output_high(pwm2);
         do
           output_low(pwm2);
           output_high(pwm1);
         while(input(PIN_a1));
           output_high(pwm1);
           output_high(pwm2);
           output_low(up1); //CCW bawah
           output_high(down1);
           output_low(up2); //CCW bawah
           output_high(down2);
      if(!input(PIN_a2)) //limit switch down
          output_high(pwm1);
          output_high(pwm2);
         do
           output_low(pwm1);
           output_high(pwm2);
         while(input(PIN_a4));
           output_high(pwm1);
           output_high(pwm2);
           output_high(up1); //CW atas
           output_low(down1);
           output_high(up2); //CW atas
           output_low(down2);
     if(!input(PIN_a4)) //limit switch down
          output_high(pwm1);
          output_high(pwm2);
         do
           output_low(pwm2);
           output_high(pwm1);
         while(input(PIN_a2));
           output_high(pwm1);
           output_high(pwm2);
           output_low(down1);
           output_low(down2);
      output_high(pwm1);
      output_high(pwm2);
here is my butterfly:
here is my circuit:
But its not follow what i want.. can anybody give a comment on my coding? thanks...
