Kill Switch Question
Setna
PostPosted: Mon Jun 30, 2008 11:13 am     Reply with quote
I'm using a PIC18F6722 and I'm looking for a simple way to make a remote kill switch. The PIC itself is going to be sealed in watertight capsule and attached to a remote control submarine that it is controlling. The sub is generally set to run at about 2 ft underwater so most typical sensors wont work.
I am currently thinking of using another R/C receiver on a different frequency that would control a switch. This switch would control the link between the PIC and its power source. Any other suggestions would be greatly appreciated.
Steve H
PostPosted: Wed Jul 02, 2008 10:57 am     Reply with quote
It sounds like you have communication to the PIC already via some radio link. If so then just add a kill command to your list of commands and use a circuit something like this to have the PIC shut off it's own power.
w w w. edn. c o m / article / CA6317068 . h t m l
HTH - Steve H.
SherpaDoug
PostPosted: Wed Jul 02, 2008 12:28 pm     Reply with quote
How about using the PIC Watchdog timer. If it does not get a valid command (including a null command) before the watchdog times out it kills itself. If you want to kill it just shut off the command transmitter.
