16f873 programmer
Calamar
View user's profile Send private message Send e-mail MSN Messenger
16f873 programmer
PostPosted: Wed Apr 02, 2003 7:13 pm     Reply with quote
I am looking for some
hvp programmer(hardware)
for the 16f873
Thanks...
___________________________
Original Post ID: 13332
Best Regards
Daniel H. Sagarra
La Plata (Argentina)
Re: 16f873 programmer
PostPosted: Thu Apr 03, 2003 1:30 am     Reply with quote
:=I am looking for some
:=hvp programmer(hardware)
:=for the 16f873
Are you looking for suggestions on which one to buy ?
If you want the one that is the most "compatible", then
I suppose you should buy a Pic-Start Plus. That's the
reason why I bought one. It's not perfect. It occasionally
can be sensitive to your serial port settings (such as, if the
fifo is enabled in Win98). It's also expensive, compared
to the others. And, it seems like I have to upgrade it
constantly lately, and that's a time-consuming process.
(ie., it's not flash upgradeable. You have erase and program
the 17C44 PIC each time).
There's also Warp-13a, but it has its own bugs.
Here's the home page for that one:
<a href="http://www.newfoundelectronics.com/warp-13a.htm" TARGET="_blank">http://www.newfoundelectronics.com/warp-13a.htm</a>
Original Post ID: 13341
Calamar
PostPosted: Thu Apr 03, 2003 6:41 pm     Reply with quote
:=:=I am looking for some
:=:=hvp programmer(hardware)
:=:=for the 16f873
:=Are you looking for suggestions on which one to buy ?
:=If you want the one that is the most "compatible", then
:=I suppose you should buy a Pic-Start Plus. That's the
:=reason why I bought one. It's not perfect. It occasionally
:=can be sensitive to your serial port settings (such as, if the
:=fifo is enabled in Win98). It's also expensive, compared
:=to the others. And, it seems like I have to upgrade it
:=constantly lately, and that's a time-consuming process.
:=(ie., it's not flash upgradeable. You have erase and program
:=the 17C44 PIC each time).
:=There's also Warp-13a, but it has its own bugs.
:=Here's the home page for that one:
:= <a href="http://www.newfoundelectronics.com/warp-13a.htm" TARGET="_blank"> <a href="http://www.newfoundelectronics.com/warp-13a.htm" TARGET="_blank">http://www.newfoundelectronics.com/warp-13a.htm</a></a>
Original Post ID: 13387
Best Regards
Daniel H. Sagarra
