I have a problem with the PIC16f677. I am using the compiler PCWH 4,041
and when I run the MPLAB "8.10" and compile the SW with MPLAB 8.10 returned this error:
Verifying...
...Program Memory
...Debug Executive
...Debug Vector
...Verify Succeeded
Programming Configuration Bits
.. Config Memory
Verifying configuration memory...
...Verify Succeeded
Connecting to debug executive
ICD0083: Debug: Unable to enter debug mode. Please double click this message for more information.
MPLAB ICD 2 Ready
How can it be?
Best regards
Posted: Mon Jun 30, 2008 9:21 am
Did you double click the message as suggested to get more information?
Read the ICD2 release note supplied with MPLAB. For the PIC16F677 you will find:
(1) Header interface board required. See Header Board Specification (DS51292), for a list of available headers by device number.
The PIC16F677 is a device with only 20 pins. To conserve I/O pins Microchip has removed (part of) the ICD hardware from the chip. In order to do in circuit debugging you will have to buy a special PCB with a little electronics adding the debugging functionality. For a simple hobby project it is cheaper to move to another chip that has the ICD functionality included.
