Trouble with 25LC256
boris
PostPosted: Thu Jun 26, 2008 8:48 am     Reply with quote
Hi!
I've created a circuit that uses a 25LC256 SPI EEPROM. My problem is that it seems I can write data to the EEPROM, but when I try to read it, the EEPROM SO pin stays in HIGH IMPEDANCE mode. I tried to change the "SPI_CLK_DIV_16" to "SPI_CLK_DIV_4", samle the signal at the end, etc, but nothing worked so far.
The code I use:
#include "main.h"
#define EEPROM_SELECT PIN_A2
char adat;
   setup_adc(ADC_OFF);
   setup_spi(SPI_MASTER|SPI_L_TO_H|SPI_CLK_DIV_16|SPI_SS_DISABLED);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
      puts( " *************************** " );
      puts( " *   Boris Technologies    * " );
      output_high(EEPROM_SELECT);
      output_low(EEPROM_SELECT);
      spi_write(0x06);    //Set the write enable latch (enable write operations)
      spi_write(0x02);    //write command
      spi_write(0x00);    //address low
      spi_write(0x00);    //address high
      spi_write(0x66);    //data to write
      delay_ms(10);
      spi_write(0x03);   //read command
      adat = spi_read();
      printf("data: %u\n\r",adat);
      spi_write(0x05);   //Read STATUS register
      adat = spi_read();
      printf("status reg: %u\n\r",adat);
the main.h contains:
#include <16F88.h>
#device adc=8
#FUSES HS                       //High speed Osc
#FUSES PUT                      //Power Up Timer
#FUSES MCLR                     //Master Clear pin enabled
#FUSES NOFCMEN                  //Fail-safe clock monitor disabled
#FUSES NOIESO                   //Internal External Switch Over mode disabled
#use rs232(baud=9600,parity=N,xmit=PIN_A0,rcv=PIN_A1,bits=8,FORCE_SW)
And I've created a simlation with Proteus, the results:
The circuit:
Thanks for the help!
PostPosted: Thu Jun 26, 2008 11:02 am     Reply with quote
Your program to interface to the eeprom is just a bunch of inline code.
You should write it as a driver, with routines that are called to init the
eeprom, and to read from it, and to write to it. If you write it as a
driver and put it in a separate file, then the code is re-usable for all
future projects. You can just "#include" it in your next project.
See the 25LC640 hardware SPI driver in this post for an example:
http://www.ccsinfo.com/forum/viewtopic.php?t=28199&start=1
Also, look closely at your usage of the spi_read() function. In CCS,
you need to give that function a parameter (usually 0x00) so that the
compiler will generate code to create the SPI clock signal during the
read operation. Without the parameter, there is no clock, and there is
no read. See the link above for an example.
boris
PostPosted: Thu Jun 26, 2008 12:26 pm     Reply with quote
Hi PCM programmer!
I made a driver to read and write the eeprom, but it didn't work, so I narrowed down the code to a few lines to test what's wrong.
I use CCS v4.074 and the help says exactly:
If this device is the master then either do a SPI_WRITE(data) followed by a SPI_READ() or do a SPI_READ(data). These both do the same thing and will generate a clock. If there is no data to send just do a SPI_READ(0) to get the clock.
So based on the help my code should work, but I try what you suggested.
Thanks!
