xavier
PIC16F88 and PWM |
Posted: Tue Jun 24, 2008 12:51 am |
I'm trying to do PWM with a PIC16F88 and it's not working.
My example is very simple and I don't understand where i'm wrong.
With output_low and output _high pin B3 is working fine but not with PWM !
I'tried to compile it with v4.032 and v3.190 no change !
Can somebody show me the way ...please
The Code :
#include <16F88.h>
#use delay(clock=20000000)
#use rs232(baud=115200,parity=N,xmit=PIN_B5,rcv=PIN_B2,bits=8,errors)
byte value;
set_tris_b(0b11110111); // B3 Output
setup_ccp1(CCP_PWM);
setup_timer_2(T2_DIV_BY_4, 255, 1);
set_pwm1_duty(0); // PWM off
printf("Starting\n\r");
while( TRUE )
value++;
printf("%2X\r",value);
set_pwm1_duty(value);
Many thanks in advance
Xavier |
sandropiovesana
Posted: Tue Jun 24, 2008 2:00 am |
I've fast read your code, my first idea is:
try to change:
with:
setup_timer_2(T2_DIV_BY_4, 100, 1);
Good Luck |
stewart
Posted: Tue Jun 24, 2008 9:11 am |
xavier
PWM is super easy. It simply is based on 3 things: TMR2, CCPR1 and PR2
CCPR1 holds the period, at which point TMR2 is reset, and the output goes high. when TMR2 matches the value of PR2, the output is cleared.
Read the data sheet in this area, look-up the actual addresses of these registers and look at the listing file to see what these functions really do.
I can have a PWM running in less than 20 instructions in assembly, you have less than 4 statements to look at what they are doing in this C program.
DIVE INTO THE CODE IT HAS GENERATED
Dig a bit,
Stewart |
Posted: Tue Jun 24, 2008 12:09 pm |
I stripped your program down somewhat by getting rid of all the printf
statements, and then I compiled it with vs. 4.074 and ran it on a
PicDem2-Plus board. It works. I see PWM output on pin B0.
#include <16F88.h>
byte value;
value = 0;
value++;
Edit: Initialized 'value' to 0.
Last edited by PCM programmer on Wed Aug 26, 2009 7:13 pm; edited 1 time in total |
xavier
PIC16F88 and PWM |
Posted: Wed Jun 25, 2008 1:38 am |
Many thanks PCM programmer for your help I found my pb ! (you mention RB0 in your post)
It was just because my scope was on RB3 instead of RB0 !!!
I'm so sorry i was sure pwm pin was RB3. (as i said on my first post)
Anyway all is working fine now ( since the beginning in fact ! )
Thanks again
Xavier |
