Any help to modify code for servomotor of PIC16F877 pls??
kingseow
View user's profile Send private message Yahoo Messenger MSN Messenger
PostPosted: Sun Jun 22, 2008 10:02 am     Reply with quote
hi, i'm currently working on humanoid robot and now searching for the best microcontroller that can work with my algorithm.
I am new with PIC16F877a for this projects and as far as i'm concern,
the design consist 5 servo motors that should run independently at the same time.This is the servomotor i will use (HS-55):
http://www.hobbyhorse.com/hitec_hs55.shtml
i have search throughout this forum and i didn't find anything related about it, or maybe i did miss it. hope all u guys can give me any ideas and suggestions.
thanks.
This is the code i have try myself...but it seen like doesn't work =.=
unsigned cnt1;
unsigned short cnt2,cnt3,cnt4;
unsigned short move_axis1,move_axis2,move_axis3,move_axis4,move_axis5;
unsigned short position_axis1,position_axis2,position_axis3,position_axis4,position_axis5;
unsigned short enable_axis1, enable_axis2, enable_axis3, enable_axis4, enable_axis5;
unsigned short read_axis1, read_axis2, read_axis3, read_axis4, read_axis5;
unsigned short step;
unsaxis1ort speed_axis1,speed_axis2,speed_axis3,speed_axis4,speed_axis5;
unsigned short mode;
void interrupt() {
//interrupt Routine
  cnt1++;                   // 0.065ms
  TMR0   = 232;
  INTCON = 0x20;           // Set T0IE, clear T0IF
  OPTION_REG = 0x80;       // Assign prescaler to TMR0
  TRISB = 0;               // PORTB is output
  PORTB = 0xFF;            // Initialize PORTB
  TRISD = 0;
  PORTD = 0;
  TMR0  = 232;
  INTCON = 0xA0;           // Enable TMRO interrupt
  cnt1 = 0;                 // Initialize cnt
  cnt2 = 0;
  cnt3 = 0;
  move_axis1 = 9;
  move_axis2 = 9;
  move_axis3 = 9;
  move_axis4 = 9;
  move_axis5 = 9;
  position_axis1 = 9;
  position_axis2 = 9;
  position_axis3 = 9;
  position_axis4 = 9;
  position_axis5 = 9;
  enable_axis1 =0;
  enable_axis2 =0;
  enable_axis3 =0;
  enable_axis4 =0;
  enable_axis5 =0;
  speed_axis1 = 4;
  speed_axis2 = 4;
  speed_axis3 = 4;
  speed_axis4 = 4;
  speed_axis5 = 4;
  mode=1;
  step=1;
  EEprom_Write(1, 0);   //for immediate serial execution; refer from senior
  Delay_ms(20);
  EEprom_Write(2, 0);
  Delay_ms(20);
  EEprom_Write(3, 0);
  Delay_ms(20);
  EEprom_Write(4, 0);
  Delay_ms(20);
  EEprom_Write(5, 0);
  Delay_ms(20);
  EEprom_Write(51, 141);
  Delay_ms(20);
  EEprom_Write(52, 138);
  Delay_ms(20);
  EEprom_Write(53, 134);
  Delay_ms(20);
  EEprom_Write(54, 138);
  Delay_ms(20);
  EEprom_Write(55, 141);
  Delay_ms(20);
  EEprom_Write(101, 0);
  Delay_ms(20);
  EEprom_Write(102, 0);
  Delay_ms(20);
  EEprom_Write(103, 0);
  Delay_ms(20);
  EEprom_Write(104, 0);
  Delay_ms(20);
  EEprom_Write(105, 0);
  Delay_ms(20);
  EEprom_Write(151, 0);
  Delay_ms(20);
  EEprom_Write(152, 0);
  Delay_ms(20);
  EEprom_Write(153, 0);
  Delay_ms(20);
  EEprom_Write(154, 0);
  Delay_ms(20);
  EEprom_Write(155, 0);
  Delay_ms(20);
  EEprom_Write(201, 0);
  Delay_ms(20);
  EEprom_Write(202, 0);
  Delay_ms(20);
  EEprom_Write(203, 0);
  Delay_ms(20);
  EEprom_Write(204, 0);
  Delay_ms(20);
  EEprom_Write(205, 0);
  Delay_ms(20);
//PWM: inverted high to low
  do {
    if (cnt1>(position_axis1+14) && enable_axis1 ==1){
       PORTD.F0=1;
    if (cnt1>(position_axis2+14) && enable_axis2 ==1){
       PORTD.F1=1;
    if (cnt1>(position_axis3+14) && enable_axis3 ==1){
       PORTD.F2=1;
    if (cnt1>(position_axis4+14) && enable_axis4 ==1){
       PORTD.F3=1;
    if (cnt1>(position_axis5+14) && enable_axis5 ==1){
       PORTD.F4=1;
//Time frame
    if (cnt1 > 400) {
       cnt1=0;
       cnt2++;                 //20ms
       PORTD=0;
//Speed Control routine
       if (cnt2%speed_axis1==0) {
          if (position_axis1 > move_axis1) {
             position_axis1--;
          if (position_axis1 < move_axis1) {
            position_axis1++;
       if (cnt2%speed_axis2==0) {
          if (position_axis2 > move_axis2) {
             position_axis2--;
          if (position_axis2 < move_axis2) {
            position_axis2++;
       if (cnt2%speed_axis3==0) {
          if (position_axis3 > move_axis3) {
             position_axis3--;
          if (position_axis3 < move_axis3) {
            position_axis3++;
       if (cnt2%speed_axis4==0) {
          if (position_axis4 > move_axis4) {
             position_axis4--;
          if (position_axis4 < move_axis4) {
            position_axis4++;
       if (cnt2%speed_axis5==0) {
          if (position_axis5 > move_axis5) {
             position_axis5--;
          if (position_axis5 < move_axis5) {
            position_axis5++;
//Time frame and demonstration code
       if (cnt2>50){          //1s
          PORTB = ~PORTB;      // Toggle PORTB LEDs
          cnt2 = 0;             // Reset cnt
          if (mode ==1) {
             cnt3++;
             if (cnt3>30) {
                cnt3=0;
             if (cnt3==1){
                enable_axis1=1;
                enable_axis2=0;
                enable_axis3=0;
                enable_axis4=0;
                enable_axis5=0;
                move_axis1=8;
             if (cnt3==3){
                move_axis1=15;
             if (cnt3==5){
                move_axis1=8;
             if (cnt3==7){
                enable_axis1=0;
                enable_axis2=1;
                move_axis2=13;
             if (cnt3==9){
                move_axis2=6;
             if (cnt3==11){
                move_axis2=13;
             if (cnt3==13){
                enable_axis2=0;
                enable_axis3=1;
                move_axis3=13;
             if (cnt3==15){
                move_axis3=3;
             if (cnt3==17){
                move_axis3=13;
             if (cnt3==19){
                enable_axis3=0;
                enable_axis4=1;
                move_axis4=15;
             if (cnt3==21){
                move_axis4=3;
             if (cnt3==23){
                move_axis4=15;
             if (cnt3==25){
                enable_axis4=0;
                enable_axis5=1;
                move_axis5=13;
             if (cnt3==27){
                move_axis5=3;
             if (cnt3==29){
                move_axis5=13;
  } while(1); //infinite loop
}//end program
