Markdem
Sleep and waking up |
Posted: Sat Jun 21, 2008 1:54 am |
Hi all, I am trying to put a PIC to sleep in int_rb. Problem is, it will not wake back up when the interrupt fires again. It looks like the ISR fires, as it will print "Power Fail" on the LCD. I have tried both on real hardware and in simulator, but both will not reset.
#include <18F4550.h>
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN,BROWNOUT,NOMCLR
#use delay(clock=48000000)
#define POWER_FAIL_SENSE_PIN PIN_B7
#include "LCD420.c"
int16 count;
int1 PF = 0, do_ISR = 0;
#int_rb
void rb_isr()
if(!input(POWER_FAIL_SENSE_PIN))
printf(lcd_putc,"\f");
lcd_gotoxy(5,2);
printf(lcd_putc,"Power Fail");
PF = 1;
sleep();
delay_cycles(1);
if(input(POWER_FAIL_SENSE_PIN) && PF == 1)
reset_cpu();
lcd_init();
printf(lcd_putc,"Running");
enable_interrupts(INT_RB);
count++;
lcd_gotoxy(1,2);
printf(lcd_putc,"count:%Lu",count);
I have also tried to set a flag inside void rb_isr(), but then the pic locks up before it prints out "Power Fail".
I have got debounce hardware on B7.
Can anyone help he out.
Thanks. |
Humberto
Posted: Sat Jun 21, 2008 10:48 am |
I never tryed, but according to the datasheet, a fixed delay is required when leaving Sleep
and Idle modes. The needed delay is for Oscillator Strt-up and the PLL lock time out.
The needed delay is only of a few machines cycles, hence 10 machines cycles inside
an interrupt would be enough.
#int_rb
void rb_isr()
delay_cycles(10);
lcd_gotoxy(5,2);
PF = 1;
sleep();
delay_cycles(1);
reset_cpu();
Humberto |
Posted: Sat Jun 21, 2008 2:39 pm |
Inside the ISR, the interrupt flag has _not_ been cleared. If you go to sleep with an interrupt flag already set, that interrupt, cannot wake you up.
You need:
PF = 1;
clear_interrupts(INT_RB);
sleep();
delay_cycles(1);
The 'clear', should be the last instruction before the interrupt.
