help! how can I change baud rate?
spilz
PostPosted: Thu Jun 19, 2008 7:00 am     Reply with quote
hello,
I have a stupid problem and I don't find how to resolve it:
I use a 16f876a and I need to change baud rate during the use
I try it
#use rs232(baud=115200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
//later
#asm
bcf 0x03,5
bsf 0x03,6  ;banque 1
bcf 0x98,2 ;low speed
movlw 64
movwf 0x99 ; 64 in SPBRG for 4800 baud
bcf 0x03, 5
bcf 0x03,6
#endasm
but the baud rate is not change
can you explain me how to do??
thanks
spilz
SherpaDoug
PostPosted: Thu Jun 19, 2008 7:19 am     Reply with quote
How about using a second #use RS232 line? There is also a set_uart_speed() function in my version 3.242 compiler. What compiler version and which PIC are you using?
spilz
PostPosted: Thu Jun 19, 2008 7:31 am     Reply with quote
I am using v4.065
there is only one uart in this pic, and if I use for exemple :
if(i==1){
#use rs232(baud=115200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)}
else{
#use rs232(baud=4800,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)}
it's always the same baud rate whatever i value.
PostPosted: Thu Jun 19, 2008 8:44 am     Reply with quote
The 'point' about a second #use RS232, is you declare it as a second stream, then you can putc/getc, to this stream when you want one rate, and to the other for the second rate. The #use RS232, will _always_ use the value declared in the _last_ definition 'passed' (does not listen to run time tests), unless you use a stream designator. You can have multiple #use RS232 declarations, by branching in a different way (a search here will find references to this).
set_uart_speed, is the easiest way to do this if you only want to change speeds (the second stream is the only way to support things like parity changes as well).
If you want to access the SPBRG register directly, just use the #byte directive. You are accessing bank 1. The BRG, is address 19, in bank 1, not 99. The compiler is smart enough to do this, if you simply tell it to access address 0x99 (it'll automatically bank switch, unless you use the 'ASIS' directive.
So the 'C' way to do what is in your assembler is:
#byte SPBRG=0x99
#byte TXSTA=0x98
#bit BRGH=TXSTA.2
BRGH=0; //select /64 prescaler
SPBRG=64; //set clock to Fosc/(64*65) - 4800bs for 2MHz Fosc
The easiest way to change the speed is:
//Or (the simplest).
If (i==1) set_uart_speed(115200);
else set_uartspeed(4800);
Now, if your master oscillator is 2Mhz (as your code suggests), I'm surprised the compiler doesn't complain when you try to select 115200bps. this is not achievable from a 2MHz clock with acceptable accuracy (normally you can reckon on anything beyond about 4% error, will fail to work). If your clock is not 2MHz, rethink your calculations....
Best Wsihes
PostPosted: Fri Jun 20, 2008 12:54 am     Reply with quote
thanks, it works fine
spilz
