migrating 18f452 to pic18LF4525 uart to EUSART problem
karth
PostPosted: Fri Jun 13, 2008 10:50 am     Reply with quote
guys i need some guidance with this,
I am switching mcu from 18f452 to 18LF4525
rock = 20Mhz
vdd = 3.4Vdc
ccs compiler=3.236
mplab ide= v8.0
tools= real ice
i have done 80% percent of the work... and i am stuck with the uart.
tx is working
rx not working
with the 18f452 the code was 100% working...so im pretty sure is not the code it got to do with some configuration, am i right?
any pointer???
#include <18F4525.h>
#device adc=10
#FUSES HS
#FUSES WDT                    //No Watch Dog Timer
#FUSES NOPROTECT                //Code not protected from reading
//#FUSES NOOSCSEN               //
#FUSES NOWDT                  //
#FUSES CCP2C1                 //
#FUSES NOBROWNOUT             //Reset when brownout detected
#FUSES PUT                     //No Power Up Timer
#FUSES NOCPD                    //No EE protection
#FUSES NODEBUG                  //No Debug mode for ICD
#FUSES NOLVP                   //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES NOWRT                    //Program memory not write protected
#FUSES NOWRTD                   //Data EEPROM not write protected
#FUSES NOWRTC                   //configuration not registers write protected
#FUSES NOWRTB                   //Boot block not write protected
#FUSES NOEBTR                   //Memory not protected from table reads
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES NOCPB                    //No Boot Block code protection
#FUSES NOPROTECT
#fuses HS,WDT128,NOPROTECT,PUT,NOBROWNOUT,NOLVP
#use i2c(Master,sda=PIN_C4,scl=PIN_C3, FORCE_HW, SLOW) // hw I2C
#use rs232(baud=4800,xmit=PIN_C6,rcv=PIN_C7,bits=8,parity=N,BRGH1OK,ERRORS)
#byte LATC = 0x0F8B
#byte LATD = 0x0F8C
#byte LATE = 0x0F8D
#byte RCSTA = 0x0FAB
#bit  OERR = RCSTA.1
#bit  CREN = RCSTA.4
in the main
setup_adc_ports(AN0);
   setup_psp(PSP_DISABLED);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_2(T2_DIV_BY_16,195,16);
   setup_timer_1(T1_DISABLED);
   setup_low_volt_detect(FALSE);
   set_tris_a(0xff);
   set_tris_b(0xff);
   set_tris_c(0xbc);
   set_tris_d(0x81);
   set_tris_e(0x06);
   init_ext_eeprom();
  // write_inmem_168(MCU_INITIALS_ADDR,0xff);
   internal_mem_init();
   disable_interrupts(GLOBAL);
   enable_interrupts(INT_RDA);
   enable_interrupts(INT_RB);
   enable_interrupts(INT_EXT1);
   //enable_interrupts(INT_EXT);
   GPSLOCKPIN=TRUE;
treitmey
PostPosted: Fri Jun 13, 2008 11:33 am     Reply with quote
just some notes..
I went from 18F452 to 18F4525 with no problems.
I use defines
#bit  CREN =0XFAB.4
#bit  OERR =0XFAB.1
#byte RCREG=0XFAE
karth
PostPosted: Fri Jun 13, 2008 1:45 pm     Reply with quote
can you copy the eusart portion of your code
thanks
treitmey
PostPosted: Mon Jun 16, 2008 8:17 am     Reply with quote
sure: this is for compiler 3.249
also see
C:\Program Files\PICC\Drivers\RS485.C
C:\Program Files\PICC\Examples\EX_SISR.C
note that timer1 counts is reset when we RX a byte. Then when not receiving data counts down and indicates an idle bus.
//"startup code " disable rda till we are ready
  disable_interrupts(INT_RDA);//disable RX
//=====================RS485_init======================//
//Setup for RS485 communications
//init must be run before anything else
void RS485_init(void)
  setup_timer_1(T1_INTERNAL | T1_DIV_BY_1);
  set_timer1(Timer1_Initial_Value);
  enable_interrupts(INT_TIMER1);//this timer waits for an idle bus
  //we wait for idle bus to know that we start reading com in the right place
  CREN = 0;
  CREN = 1; //clear overflow error if something snuck in
  if (!idle_bus)//wait for buss to go idle.  Then start reading pkt's
    restart_wdt();
//=====================tx_buffer======================//
//For transmitting data via USART and using interrupts
//must have #INT_TBE defined
void tx_buffer(char *data,int8 size)
  int8 x;
  disable_interrupts(INT_TBE); //so as not to change indx_i in 2 places, isr and here
  for (x=0;x<size;x++,data++)
    //chksum=chksum+*data;
    TX_BUF[tx_indx_i] = *data;
    tx_indx_i++; //increment the index
    //tx_indx_i &= TXMASK;  //not needed its an int8
    if(tx_indx_o==tx_indx_i)  //if the indexs match we are full
      bit_set(ERRORS,1);//set error flag bit 1 for tx overflow
      //disable_interrupts(INT_TBE);
      //tx_indx_o++;
      //tx_indx_o &= TXMASK; //not needed its an int8
  enable_interrupts(INT_TBE);
  return;
//=======================TXisr============================//
//Takes data from buffer and puts it into a TX stream (RS485)
//uses interrupts to empty buffer at proper rate
#INT_TBE
void TXisr(void)
  CREN = 0;
  idle_bus=FALSE;
  fputc(TX_BUF[tx_indx_o],RS485);
  tx_indx_o++;      //not used//tx_indx_o &= TXMASK;
    CREN = 1;
//=======================RXisr============================//
//Takes RX data from a stream and puts it into a buffer via interrupts
#INT_RDA
void RXisr(void)
  idle_bus=FALSE;
  RX_BUF[rx_indx]=RCREG;
  rx_indx++;
  if (rx_indx==MAXHEADER+MAXDATA+1) // check for buffer overflow
    bit_set(ERRORS,2);//set error flag bit 2 for RXbuffer overflow
  if (OERR)
    bit_set(ERRORS,0);//set error flag bit 0 for USART overflow
    CREN = 0;
    CREN = 1;
//=======================checksum============================//
int8 chksum(char *data,int8 size)
  int8 x;
  int8 chksum=0;
    //fprintf(DEBUG,".");
  return(chksum);
karth
PostPosted: Mon Jun 16, 2008 1:27 pm     Reply with quote
i am using Asynchronous mode and the compiler i am using is 3.236 is that compatible with pic18lf4525???
treitmey
PostPosted: Tue Jun 17, 2008 8:03 am     Reply with quote
It could be the compiler version, or something to do with the "LF" version
of the chip.
Charlie U
PostPosted: Tue Jun 17, 2008 12:21 pm     Reply with quote
Check the specs for the part that you are using. Look at figure 26-3 in the latest data sheet. There is a formula for max operating frequency vs supply voltage. If I am not mistaken, using this formula, the max operating frequency is 18.9MHz at 3.4v. If you are making a one off project, you might get lucky and get away with this. If this is a commercial product, you might consider some changes.
treitmey
PostPosted: Tue Jun 17, 2008 2:33 pm     Reply with quote
I never caught that he was running at that low of a voltage. Good catch.
karth
PostPosted: Wed Jun 18, 2008 7:59 am     Reply with quote
i spoke to microchip, for 3.5 v 20mhz rock is fine....
