#USE SPI for multiple streams
bwhiten
PostPosted: Fri Jun 13, 2008 7:05 am     Reply with quote
I'm looking for an example using the #USE SPI method rather than the setup_spi method. #USE SPI has the STREAM = option and I need to run two device speeds on the same SPI bus. One at 10MHz and the other at 5MHz. I have separate chip selects for these.
Seems when I search the forum for combinations of #USE and SPI I get the same 1034 posts with little relevance to my question.
RLScott
Re: #USE SPI for multiple streams
PostPosted: Fri Jun 13, 2008 7:20 am     Reply with quote
You could just avoid the CCS library of SPI functions and write your own code by talking directly to the SPI registers. You could reconfigure the SPI clock speed before each transaction so as to customize the speed for the slave device. The SPI interface is fairly simple and is well-documented in the Microchip datasheets.
Robert Scott
Real-Time Specialties
bwhiten
PostPosted: Fri Jun 13, 2008 8:11 pm     Reply with quote
RLS, You may over-estimate my programming abilities Smile Mostly hardware design here until I began using PICs. I would hope, for my needs, the library functions would suffice. That is if they work. I can use the spi_setup just fine individually, and that code works, but when I use the #USE SPI version of setup things don't go so well.
RLScott
PostPosted: Sat Jun 14, 2008 4:55 am     Reply with quote
What, then, is the problem with using the spi_setup version of the code?
Robert Scott
Embedded Systems Consulting
bwhiten
PostPosted: Sat Jun 14, 2008 8:59 am     Reply with quote
I not sure how to switch speeds during run time using the setup_spi command. Is it possible to use it at the beginning of each access to a device?
PostPosted: Sat Jun 14, 2008 7:10 pm     Reply with quote
In my code I have two SPI setup functions with different speed settings, like:
// Setup the SPI bus with a slow clock speed (16MHz / 64 = 256kHz).
// RTC has a max. speed of 1MHz, but MMC and FRAM go to 20MHz and SD even to 25MHz.
void SPI_SlowClock()
  setup_spi(SPI_MASTER | SPI_MODE_3 | SPI_CLK_DIV_64);
// Setup the SPI bus with a fast clock speed (16MHz / 4 = 4MHz).
void SPI_FastClock()
  setup_spi(SPI_MASTER | SPI_MODE_3 | SPI_CLK_DIV_4);
My clock speed is 16MHz and depending on the selected device I call one of the two functions. Example:
// Select the specified device on the SPI bus and set the SPI clock speed.
// Calling this function assures no two devices will be active at the same time.
void SPI_Select(spi_device Device)
  // Disable all SPI devices
  // Note that some devices need a high level and others a low level.
  output_low(RTC_SELECT);       // Active high
  output_high(FRAM_SELECTinv);  // Active low
  output_high(MMC_SELECTinv);   // Active low
  switch (Device)
    case SPI_NO_DEVICE:
      // Deselect all devices.
      // Nothing to do here, devices already deselected
    case SPI_RTC:
      // Select Real Time Clock
      SPI_SlowClock();
      delay_us(5);                  // RTC is slow; at least 4 us required between selects
      output_high(RTC_SELECT);      // Active high
      delay_us(5);                  // RTC is slow; at least 4 us after CE is activated
    case SPI_FRAM:
      // Select FRAM
      SPI_FastClock();
      output_low(FRAM_SELECTinv);   // Active low
    case SPI_MMC:
      // Select MMC Card flash memory
      SPI_FastClock();
      spi_write(0xFF);              // Allow 8 dummy clocks before asserting CS again
      output_low(MMC_SELECTinv);    // Active low
    default:
//      fprintf(ToLog, "Error: Unknown spi device selected\n\r");
Ken Johnson
PostPosted: Sun Jun 15, 2008 8:04 am     Reply with quote
Look at the generated assembly code.
I believe that when you use the #use spi with the stream option, the spi is setup on each call to write_spi(). If you use setup_spi(), then that setting remains in effect until another setup_spi().
Ken
bwhiten
Thanks for the knowledge
PostPosted: Sun Jun 15, 2008 9:26 am     Reply with quote
I hadn't realized you could repeatedly call setup_spi with different parameters during runtime. I guess I was treating it like a preprocessor directive. I'll give that a try next.
Thanks again.
