jinggy
RFID. need help |
Posted: Wed Jun 11, 2008 8:43 pm |
hello all.
i'm using a RFID reader module from parallax
[url]
http://www.parallax.com/dl/docs/prod/audiovis/RFID-Reader-v1.1.pdf [/url] to read 12-byte tags and display on a LCD screen.
but instead of getting ID such as 0F02A670DF or 0F02A66F79, i get some weird symbols like {6/ @ ^ &). anybody knows why?
here's my codes:
#include <18F4550.h>
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV2,VREGEN
#use delay(clock=48000000)
#include <lcd.c>
#define LCD_E PIN_D0
#define LCD_RS PIN_D1
#define LCD_RW PIN_D2
#define LCD_DB4 PIN_D4
#define LCD_DB5 PIN_D5
#define LCD_DB6 PIN_D6
#define LCD_DB7 PIN_D7
#define TX PIN_C6
#use rs232(baud = 2400, rcv = PIN_C7)
void main( void )
int i=0;
byte buf[12];
lcd_init();
output_low(PIN_C6);
delay_ms(2000);
for (i=0;i<12;i++) {
buf[i] = getc();
lcd_putc(buf[i]);
thanks in advance! |
Posted: Thu Jun 12, 2008 2:26 am |
Obvious thing, check your clock rate.
From what you show, you have a 20MHz crystal?.
PLL5, is then correct. Otherwise this needs to change.
Then CPUDIV2, will give you a master clock at _24MHz_, not the 48MHz that you have selected in the clock statement. I'd suspect this is the problem.
The dividers here are really designed to 'confuse'. Available dividers are /1, /2, /3, and /4. When fed from the crystal source, they work as named. However from the USB clock, they are each effectively doubled in the division given!... I prefer to think that the USB clock actually comes from after the /2 divider in the USB chain, rather than before this. Not what the diagram shows, but it is what happens!. If you look carefully at table 2-3 (oscillator configuration), for your crystal, they show CPUDIV1:CPUDIV0, having to be selected as '00', for 48MHz. This is the selection that gives /1, when using the external crystal (look at figure 2-1), so the fuses need to be set to CPUDIV1...
Select this. I think you will find it starts to work.
However, add the C6 transmit pin to your UART definition (otherwise you will be using a software UART). You don't have to use the pin, but the definition needs to be there to tell the compiler to use the hardware UART. Also add the 'ERRORS' define to this.
Then use the same method shown in the example code, don't wait for two seconds, but wait for the start character, or you may be 'out of sync' with the incoming data. So:
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN
#include <lcd.c>
#define TX PIN_C6
#use rs232(baud = 2400, rcv = PIN_C7,xmit=PIN_C6,ERRORS)
void main( void )
int i=0;
byte buf[12];
lcd_init();
output_low(PIN_C6);
while (getc() != 0x0A) ; //wait for the tag
//Now only have 11 characters to read
for (i=0;i<11;i++) {
buf[i] = getc();
lcd_putc(buf[i]);
jinggy
Posted: Thu Jun 12, 2008 3:23 am |
thanks a lot Ttelmah!!!
it works! finallyyy ![Smile](images/smiles/icon_smile.gif) |
