I got a ZIP file: loader_dsp.zip from the CCS support.
This example is used for a dsPIC30F5011.
I have only used the EX_BOOTLOADER.C file with the defined LOADER setting's. But I get the following error:
Undefined identifier -Boot_Firmware_Upgrade.
Where I can get this function?
I'm searching for a efficient bootloader for the PIC24H!
Regards
Jochen
Jochen Kochner
Posted: Tue Jun 10, 2008 7:36 am
I have changed the bootloader software in this way, that I can compile the bootloader software for the PIC24H.
But if I want to load the hex file about the siow.exe tool into the PIC I get only an timeout.
