PIC18F452 / 458 Global Interrupt
Eric Girard
PostPosted: Sat Apr 05, 2003 11:42 am     Reply with quote
I'm using PCH V3.126. I need to generate an interrupt from the RTCC.
unsigned char Update = 1;
byte INTCON = 0x0FF2; //Give us access to intcon register
#int_rtcc
void RTCC_ISR
{ Update = 1; }
void main
setup_timer_0(RTCC_INTERNAL | RTCC_DIV_BY_16);
enable_interrupts(INT_RTCC);
while (1)
INTCON |= 0xC0; //<-If I force GIE set, its working
if (Update)
Update = 0;
... do something
This code is not working and should be working. I've looked at the code generated and it SHOULD be working but for some unknown reasons, GIE bit get cleared. If I set GIE at the beginning of the loop its ok but this is not a useable solution.
I know there are somes funny things about the 18F series interrupts. I would appreciate any help
Eric Girard
___________________________
Original Post ID: 13443
Mirko
Re: PIC18F452 / 458 Global Interrupt
PostPosted: Mon Apr 07, 2003 8:35 am     Reply with quote
I test youre program, and for me is OK. I used ( PIC 18F458 an PCWH 3.13)
When I download this firmware the microcontroller print "...HI..." every 1 second +/-.
Hi Mirko
#include <18F458.h>
#fuses XT,NOWDT,WDT1
int Update=0;
#int_RTCC
RTCC_isr() {
Update=1;
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_CLOCK_DIV_2);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL | RTCC_DIV_16);
setup_timer_1(T1_DISABLED);
setup_comparator(FALSE);
enable_interrupts(global);
while (1) {
if (Update) {
update=0;
printf("...HI...");
:=I'm using PCH V3.126. I need to generate an interrupt from the RTCC.
:=unsigned char Update = 1;
:=byte INTCON = 0x0FF2; //Give us access to intcon register
:=#int_rtcc
:=void RTCC_ISR
:={ Update = 1; }
:=void main
:= setup_timer_0(RTCC_INTERNAL | RTCC_DIV_BY_16);
:= enable_interrupts(INT_RTCC);
:= enable_interrupts(GLOBAL);
:= while (1)
:= INTCON |= 0xC0; //<-If I force GIE set, its working
:= if (Update)
:= Update = 0;
:= ... do something
:=This code is not working and should be working. I've looked at the code generated and it SHOULD be working but for some unknown reasons, GIE bit get cleared. If I set GIE at the beginning of the loop its ok but this is not a useable solution.
:=I know there are somes funny things about the 18F series interrupts. I would appreciate any help
:=Eric Girard
Original Post ID: 13461
