I created a project in mplab v8 and there are 2 files.
file 1 is just standard c routines.
file 2 is the file with void main () {while(1)dostuff();}
When I build all I get
Executing: "C:\Program files\Picc\CCSC.exe" +FH "C:\code\modemtest\lcd.c" +EXPORT +DF +LN +T +A +M +Z +Y=9 +EA
*** Error 70 "lcd.c" Line 237(0,1): No main() function found
1 Errors, 0 Warnings.
which is true, there is no main function. It's in the next file.
lcd.c is a bit of copy and paste I made from here to drive the lcd on a picdem 2.
The other file compiles just fine (it has a main func of course).
If I put all the code in one file it works.
The manual simply states that all programs need a main() function.
Can someone advise me what could cause this odd behavior?
