Problem with shutdown on PIC16f684
sandropiovesana
PostPosted: Wed Jun 04, 2008 8:42 am     Reply with quote
Hi All,
I have a problem when i shutdown (in firmware) the bridge because i don't have the shutdown condition indicated in my software but i have all low level on P1A,P1B,P1C,P1D. (i want high level).
I use CCS 4.073, MPLAB 8.10 and ICD2 (only for programming).
How can i have high level on P1A,P1B,P1C,P1D (using ECCP)?
How can i have high level on P1A,P1B,P1C,P1D (using another idea)?
This is my code:
#include <16F684.h>
#DEVICE ADC=10
#BIT ECCPASE = 0x17.7
#FUSES INTRC_IO                    //Internal RC Osc, no CLKOUT
#FUSES NOPROTECT                //Code not protected from reading
#FUSES NOMCLR                   //Master Clear pin used for I/O
#FUSES NOCPD                    //No EE protection
#FUSES NOWDT                      //No Watch Dog Timer
#FUSES PUT                      //Power Up Timer
#FUSES NOIESO                   //Internal External Switch Over mode disabled
#FUSES NOFCMEN                    //NO Fail-safe clock monitor enabled
#USE delay(clock=8000000)
#USE FAST_IO(A)
#USE FAST_IO(C)
#define CCP1_LOW_SPD       70      // 70% Duty-Cycle
#define CCP1_HIGH_SPD      100      // 100% Duty-Cycle
// PORT CONTROL
#define TRISA_SETUP   0b11111110
#define TRISC_SETUP   0b11000011 // Prima con RS232 era 0b11011100
#define BJT     40   // PIN_RA0
#define VREF    41   // PIN_RA1
#define VAMP    42   // PIN_RA2
#define VPP     43   // PIN_RA3
#define JMP2    44   // PIN_RA4
#define JMP1    45   // PIN_RA5
#define VCC_2   56   // PIN_RC0
#define POL     57   // PIN_RC1
#define P1D     58   // PIN_RC2
#define P1C     59   // PIN_RC3
#define P1B     60   // PIN_RC4
#define P1A     61   // PIN_RC5
/* Global definitions used to indicate the state of a pin */
#define LOW               0
#define HIGH            1
//-                                - MAIN -                                  -
   setup_oscillator(OSC_8MHZ);
   Set_Tris_A(TRISA_SETUP);
   Set_Tris_C(TRISC_SETUP);
   setup_adc_ports(sAN2|sAN4|VSS_VREF);
   SETUP_TIMER_2 (T2_DIV_BY_4, 100, 1);
   set_pwm1_duty (CCP1_LOW_SPD);
   ENABLE_INTERRUPTS(GLOBAL);
   while (TRUE)
      SETUP_CCP1 (CCP_PWM_L_H | CCP_PWM_FULL_BRIDGE | CCP_SHUTDOWN_AC_H | CCP_SHUTDOWN_BD_H);
      ECCPASE = 1;
      ECCPASE = 0;
Datasheet:
11.4.4 ENHANCED PWM
AUTO-SHUTDOWN MODE
The PWM mode supports an Auto-Shutdown mode that
will disable the PWM outputs when an external
shutdown event occurs. Auto-Shutdown mode places
the PWM output pins into a predetermined state. This
mode is used to help prevent the PWM from damaging
the application.
The auto-shutdown sources are selected using the
ECCPASx bits of the ECCPAS register. A shutdown
event may be generated by:
• A logic ‘0’ on the INT pin
• Comparator 1
• Comparator 2
• Setting the ECCPASE bit in firmware
PostPosted: Thu Jun 05, 2008 12:15 pm     Reply with quote
The setup_ccp1() function is not writing to the ECCPAS register.
That's a bug. To fix it, add this line above main():
#byte ECCPAS = 0x017
Then add this line just after the setup_ccp1() line in your program.
This will manually setup the ECCPAS register.
ECCPAS = make8(CCP_SHUTDOWN_BD_H | CCP_SHUTDOWN_AC_H, 2);
I have reported this to CCS.
sandropiovesana
PostPosted: Fri Jun 06, 2008 12:57 am     Reply with quote
Thank You very much!!!
Sandro
