menu problem
hmg
menu problem
PostPosted: Wed Jun 04, 2008 1:07 am     Reply with quote
I have just join this forum. I am learning ccs c. Day by day progress.
I have done a clock (ds1302-ds18b20 and 2x16 lcd). It's classic but I'm learning. I did time and temperature problem. But I didn't know how can I change variables (hour,minute,day,month,year,daysofweek). I want to use 3 buttons to change variables. (adjust,reverse,forward ) When I push adjust button a cursor come or blink variable. Then I want use change variable with reverse and forward buttons. Then when I push again adjust; cursor goes to other variable .
My trial time and temp. ok but variable don't change. Thank you for your help.
#include <16f876.h>
#use delay (clock=4000000)
#include <flexyLCD1.c>
#use fast_io(c)
#include <DS1302.c>
#include <ds18b20.c>
int8 second,minute,hour,day,month,year,day_ofweek;
float temperature;
 void menu(){
  lcd_setcursor_vb(1,0);
  if(!input(pin_c1))
  {delay_ms(20);
  while(!input(pin_c1));
  day--;}
 if(!input(pin_c2)){delay_ms(20);
 while(!input(pin_c2));
  day++;}
   void main ( )
   setup_timer_1(T1_DISABLED);
   setup_CCP1(CCP_OFF);
   rtc_init();
  if(!input(pin_c0))menu();
      temperature = ds1820_read();
      rtc_get_time(hour,minute,second);
      rtc_get_date(day,month,year,dayof_week);
      lcd_gotoxy(1,2);
     printf(lcd_putc,"%02d/%02d/20%02d "day,month,year);
      switch(dayof_week)
         case 1: printf(lcd_putc," SUN"); break;
         case 2: printf(lcd_putc," MON"); break;
         case 3: printf(lcd_putc," TUE"); break;
         case 4: printf(lcd_putc," WED"); break;
         case 5: printf(lcd_putc," THU"); break;
         case 6: printf(lcd_putc,"FRI "); break;
         case 7: printf(lcd_putc," SAT"); break;
      lcd_gotoxy(1,1);
      printf(lcd_putc,"%02d:%02d:%02d %3.1f'C.",hour,minute,second,temperature);
andrewg
PostPosted: Wed Jun 04, 2008 8:54 am     Reply with quote
Where is your call to rtc_set_datetime? It looks like right after you modify day in menu(), you're overwriting it with rtc_get_date().
Andrew
