Sending a data from one CAN NODE to another using PIC16F877A
JENNIFER
PostPosted: Wed May 21, 2008 12:45 am     Reply with quote
hiii
We have tried to send a data from a CAN node to another using MCP2515, MCP2551 , PIC16F877A... there is error in the transmission progam in picc........please help on this ....Here is our code:
#define MCP2515_CS   PIN_C1
#define MCP2515_RESET_PIN PIN_C0
#define READCMD 0x03
#define WRITECMD 0x02
#include<16F877A.h>
#include<header.h>
#include<MCP2515.h>
int8 A,B,reg;
void RESETMCP2515()
   output_high(MCP2515_CS);
   output_low(MCP2515_RESET_PIN);
   delay_us(10);
   output_high(MCP2515_RESET_PIN);
int READREG(int regaddres)
   output_low(MCP2515_CS);
   spi_write(READCMD);
   spi_write(regaddres);
   reg=spi_read(0);
   return(reg);
void WRITEREG(int regaddres,int regvalue)
   spi_write(WRITECMD);
   spi_write(regvalue);
void CONFIGMCP2515()
   int cnfr1 = 0x90;
   int cnfr2 = 0x92;
   int cnfr3 = 0x84;
   WRITEREG(CANCTRL, 0x80);              //set to config mode
   WRITEREG(CNF1, cnfr1);
   WRITEREG(CNF2, cnfr2);
   WRITEREG(CNF3, cnfr3);
   WRITEREG(CANCTRL, 0x00);               //reset to normal mode
void MAIN()
   TRISB=TRISD=0x00;
   setup_spi(SPI_MASTER|SPI_H_TO_L |SPI_XMIT_L_TO_H| SPI_CLK_DIV_4   );
   RESETMCP2515();
   CONFIGMCP2515();
A=READREG(TXB0CTRL);
B=READREG(CANINTF);
WRITEREG(CANINTE,0XFF);       //TO ENABLE INTERRUPT
WRITEREG(TXB0CTRL,0X03);     // setting highest priority transmit buff 0
WRITEREG(TXB1CTRL,0X02);
WRITEREG(TXB2CTRL,0X01);
WRITEREG(TXB0SIDH,0X0F);       //identifer 0F
WRITEREG(TXB0SIDL,0X00);
WRITEREG(TXB0D0,0XFF);           //data to b send
WRITEREG(TXB0DLC,0X01);        // DATA LENGTH
BIT_SET(A,3);
L1:   IF (BIT_TEST(A,4))               // CHECK BUS AVAILABILITY
    PORTB=READREG(TXB0CTRL);
  GOTO L1;
IF(BIT_TEST(B,2))
  PORTD=0XFF;                //IF MSG  SENTSUCCESSFULLY DISPLAY FF
PORTD=READREG(CANINTF);
PostPosted: Wed May 21, 2008 1:00 am     Reply with quote
I suggest that you use the CCS driver for the MCP2515 instead of writing
your own:
c:\program files\picc\drivers\can-mcp251x.c
c:\program files\picc\drivers\can-mcp251x.h
In the follow thread, I have posted instructions on how to connect two
boards with the CAN bus and test the communications. The demo
program uses CCS driver functions, so even though the program
is for an 18F458, it should also work with the can-mcp251x.c driver.
Just change it to include that file instead of can-18xxx8.c.
http://www.ccsinfo.com/forum/viewtopic.php?t=29627
Jennifer
Data TX b/w CAN nodes (PIC16F877A & MCP2515) in PICC
PostPosted: Wed Jun 04, 2008 12:19 am     Reply with quote
hiii
We have tried to send a data from a CAN node to another using MCP2515, MCP2551 , PIC16F877A... there is error in the programs in picc........please help on this ....Here is our code for transmission and reception programs.There is error in bus availabilty.
TRANSMISSION PROGRAM:
#include<16F877A.h>
#include<PIC16F877A.h>
#include<MCP2515.h>
int8 reg,A;
void RESETMCP2515()
   delay_us(10);
   spi_write(READCMD);
   reg=spi_read(0);
   return(reg);
   int cnfr1 = 0x00;       //(Fosc=20Mhz,buadrate=1Mbps)
   int cnfr2 = 0xA0;
   int cnfr3 = 0x02;
void MAIN()
   TRISD=TRISB=0x00;
   RESETMCP2515();
   CONFIGMCP2515();
   OUTPUT_B(0X00);
   OUTPUT_D(0X00);
   WRITEREG(TXB0CTRL,0X03);                 //priority
   WRITEREG(TXB0SIDH,0X0F);                 //MSB ID
   WRITEREG(TXB0SIDL,0X00);          //LSB ID
   WRITEREG(TXB0DLC,0X01);          //data length
   WRITEREG(TXB0D0,0X09);          //DATA TO BE SEND
   WRITEREG(TXB0CTRL,0X0B);                 //to initialize trsn(TXREQ set)
   reg=READREG(TXB0CTRL);
   L1:   if (BIT_TEST(reg,4))               //CHECKING BUS AVAILABILITY
        PORTB=reg;
   GOTO L1;
        A=READREG(CANINTF);
        if(BIT_TEST(A,2))         // (CANINTF.TX0IF=1?)
           PORTD=0X0F;                     //MSG  SENT(SUCCESS)
        PORTD=0X0A;                        // NOT SEND
RECEPTION PROGRAM:
#include<16F877A.h>
#include<MCP2515.h>
int8 reg,X;
void RESETMCP2515()
   delay_us(10);
int READREG(int REGADDR)
   spi_write(READCMD);
   spi_write(REGADDR);
   reg=spi_read(0);
   return(reg);
void WRITEREG(int REGADDR,int REGVALUE)
   spi_write(REGADDR);
   spi_write(REGVALUE);
   int cnfr1 = 0x00;
   int cnfr2 = 0xA0;
   int cnfr3 = 0x02;
void MAIN()
   RESETMCP2515();
   CONFIGMCP2515();
   WRITEREG(CANINTF,0X00);
   WRITEREG(RXB0CTRL,0X20);
   WRITEREG(RXF0SIDH,0X0F);           // FILTER VALUE
   WRITEREG(RXF0SIDL,0X00);
   X=READREG(CANINTF);
L1:   if(bit_test(X,0))
   TRISD=TRISB=0x00;
        PORTB=READREG(RXB0D0);
         goto L1;
