PIC18F4431 read group ADC
KB
PostPosted: Mon Jun 02, 2008 3:47 am     Reply with quote
Helllo,
I try to read 2 channels (channel 0 and 1) using "group A and B are sampled simultaneously and converted sequentially" mode.
And read the result in a interrupt, but this seems not to be working. The only result i get is the value from one channel depends on what i set in the config "set_adc_channel()".
PIC: PIC18F4431
compiler : 4.057
code:
config adc,
setup_adc(DC_CLOCK_DIV_32|ADC_TAD_MUL_12|ADC_CONT_AB|ADC_WHEN_PPWM|ADC_INT_EVERY_OTHER);
set_adc_channel( 0 );
Interrupt:
#INT_AD
void ADCread ()
channel0= read_adc( ADC_READ_ONLY );
channel1 = read_adc( ADC_READ_ONLY );
i also try:
void ADCread ()
But that also not working.
What could be the problem?
gr
KB
PostPosted: Mon Jun 02, 2008 9:04 am     Reply with quote
What you are trying to do, is only partly supported by the CCS functions. Their setup, supports enabling the extra features on these chips, but the read_adc function, only returns the current values in the result registers, as for a normal unbuffered ADC. I'd suggest trying defining ADCON1, and changing the buffer address selection bits, between the reads. So something like:
#byte ADCON1=0xFC1
ADCON1=ADCON1 & 0xFC;
channel0=read_adc(ADC_READ_ONLY);
ADCON1++;
channel1=read_adc(ADC_READ_ONLY);
No guarantees!. You may need to enable the FIFO as well (before starting the conversions), since there does not seem to be a setting for this in the CCS code.
This is the 'problem' of the CCS fuctions, when chips appear, with new abilities.
PostPosted: Mon Jun 02, 2008 9:11 am     Reply with quote
Note also, the comment in the .h file, about using four parameters to 'set_adc_channnel', for this chip. Looks like you use something like:
set_adc_channel(0,1,NULL,NULL);
Worth some experimenting.
