murtis
| RA8835 driver |
Posted: Sat May 31, 2008 2:32 pm |
I have a graphic LCD built-in controller RA8835. But i did not driving the LCD. someone have a opinion_? or Someone have a driver_? How i can drive the LCD_? _________________ MurtiS |
murtis
| Hi again, |
Posted: Sun Jun 01, 2008 7:37 am |
Nobody send an answer. So, how can i change the driver sed1335 for driver RA8835_? i did not understand 8080 mode or 6800 mode in pin diagram. Anyone can help me about this situation_? _________________ MurtiS |
Posted: Sun Jun 01, 2008 1:31 pm |
Searching with Google for a few seconds, shows that the RA8835 is
software compatible with the SED1335/S1D13305:
http://www.mitsutech.com/new_product.html
Then, go to the Drivers directory for the CCS compiler and find this:
| Quote: | | c:\Program Files\picc\Drivers\sed1335.c |
To confirm that SED1335 = S1D13305, a little more searching
gives this data sheet. On page 3, it says that S1D13305 is a new
part number for the SED1335 chip.
http://www.topwaydisplay.com/Pub/IC_DataSheet/S1D13305-e.pdf
In the SED1335.c driver, the main control signals are listed near the
top of the file. These are:
| Quote: |
GLCD_RST
GLCD_RD
GLCD_WR
GLCD_CS
GLCD_A0
Then look at this data sheet again:
It has these two sections:
| Quote: | 6.3.1. 8080 Family Interface Timing
6.3.2. 6800 Family Interface Timing |
Go down and look at that section. On page 6 (page 12 in Acrobat reader)
it has a table. It shows the 8080 family uses A0, \RD, and \WR signals.
It shows 6800 uses A0, R/W, and E.
So clearly, the CCS driver is using the Intel 8080 signals.
The CCS sed1335.c driver has some default PIC pins assigned to the
LCD signals, as shown below. You can change these to some suitable
pins on your PIC. Make sure the pins that you select can do i/o.
Some pins on some PICs are input-only. It's also common for one
pin to be open-drain (requires an external pull-up resistor, if used as
a normal output pin). These special pins are usually on Port A.
Read the "Overview" section of the PIC data sheet to carefully check
if the i/o pins that you select are not some of these special pins.
| Code: | #ifndef GLCD_RST
#define GLCD_RST PIN_C3
#ifndef GLCD_RD
#define GLCD_RD PIN_B5
#ifndef GLCD_WR
#define GLCD_WR PIN_B1
#ifndef GLCD_CS
#define GLCD_CS PIN_B2
#ifndef GLCD_A0
#define GLCD_A0 PIN_B4
#endif |
murtis
| Hi again, |
Posted: Mon Jun 02, 2008 7:36 am |
Graphic LCD working but, something is wrong. I will send my driver code and main program... if you see the main program code, i must see the vertical line and horizontal line etc... But, i am seeing the line like this below:
some pixel is not turn on or there are many pixel turned on.
How can i solve this problem_?
driver code for RA8835 is below:
| Code: | #ifndef GLCD_WIDTH
#define GLCD_WIDTH 320
#ifndef GLCD_HEIGHT
#define GLCD_HEIGHT 240
#ifndef GLCD_CHAR_WIDTH
#define GLCD_CHAR_WIDTH 8
#ifndef GLCD_CHAR_HEIGHT
#define GLCD_CHAR_HEIGHT 8
#ifndef GLCD_RST
#define GLCD_RST PIN_B3
#ifndef GLCD_RD
#define GLCD_RD PIN_B0
#ifndef GLCD_WR
#ifndef GLCD_CS
#define GLCD_CS PIN_B4
#ifndef GLCD_A0
#define GLCD_A0 PIN_B2
SED1335.c driver code deleted by Forum Moderator.
Ref. Forum rule #10:
10. Don't post the CCS example code or drivers.
Also, you will see the main code is that below:
| Code: | unsigned int x=0,y=0,i=0;
loop1:
glcd_fillScreen(ON);
for(i=0;i<=239;i++)
glcd_pixel(0,i,OFF);
delay_ms(250);
for(i=0;i<=239;i++)
glcd_pixel(i,0,OFF);
delay_ms(250);
for(i=0;i<=239;i++)
glcd_pixel(i,i,OFF);
delay_ms(250);
glcd_fillScreen(OFF);
for(i=0;i<=239;i++)
glcd_pixel(0,i,ON);
delay_ms(250);
for(i=0;i<=239;i++)
glcd_pixel(i,0,ON);
delay_ms(250);
for(i=0;i<=239;i++)
glcd_pixel(i,i,ON);
delay_ms(250);
goto loop1; |
Posted: Mon Jun 02, 2008 12:20 pm |
1. Post the manufacturer and part number of your LCD.
2. Post your compiler version. |
murtis
| Compiler version and LCD Manufacturer |
Posted: Mon Jun 02, 2008 12:25 pm |
WG320240C0 Graphical LCD built-in RA8835 controller from Winstar
PCWH 4.071 compiler version _________________ MurtiS |
Posted: Mon Jun 02, 2008 1:55 pm |
In your main() code posted above, I don't see that you have called
the init routine. Example:
Post a complete test program. Show the #include statement for the PIC,
and the #fuses, #use delay() and #include<sed1335.c> statements.
Post all variable declarations. Show the main(). Show the code that
you posted for main above. The program should be compilable without
errors. |
murtis
Posted: Tue Jun 03, 2008 7:00 am |
Hi again,
you will see the main program that is below:
| Code: | #include "C:\Documents and Settings\Murti\Desktop\GLCD_WNSTR\glcd_wnstr.h"
#include<sed1335.c>
#include<graphics.c>
void basla_ayar()
setup_adc(ADC_OFF|ADC_TAD_MUL_0);
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
glcd_init(ON);
delay_ms(250);
void main(){
basla_ayar();
set_tris_b(0x00);
mesela:
glcd_circle(160, 120, 20, YES, OFF);
for(i=0;i<=239;i++)
delay_ms(250);
for(i=0;i<=239;i++)
delay_ms(250);
for(i=0;i<=239;i++)
delay_ms(250);
glcd_circle(160, 120, 20, YES, ON);
for(i=0;i<=239;i++)
glcd_pixel(0,i,ON);
delay_ms(250);
for(i=0;i<=239;i++)
glcd_pixel(i,0,ON);
delay_ms(250);
for(i=0;i<=239;i++)
glcd_pixel(i,i,ON);
delay_ms(250);
goto mesela;
you will see the part of the driver code from CCS that is below:
| Code: | #ifndef SED1335
#define SED1335
#ifndef GLCD_WIDTH
#ifndef GLCD_HEIGHT
#ifndef GLCD_RST
#ifndef GLCD_RD
#ifndef GLCD_WR
#ifndef GLCD_CS
#ifndef GLCD_A0
#ifndef ON
#define ON 1
#ifndef OFF
#define OFF 0
#endif |
screen view will be attached to here later. Sorry about this.
you will see the glcd_wnstr.h that is below:
| Code: | #include <18F4620.h>
#device adc=10
#FUSES XT //Crystal osc = 4mhz
#FUSES NOIESO //Internal External Switch Over mode disabled
#FUSES NOLVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#use delay(clock=4000000) |
something happened is very interesting. I could not find any error,etc.... Can you help me about this situation__? _________________ MurtiS
murtis
| Screen view |
Posted: Tue Jun 03, 2008 7:04 am |
Posted: Tue Jun 03, 2008 12:44 pm |
Your image shows a problem that occurs every 8 pixels, in the X axis.
So there might be a problem with the address calculation. Then look in
the graphics.c file, because it draws the lines. What do we find ?
For lines:
#ifdef LARGE_LCD
void glcd_line(int16 x1, int16 y1, int16 x2, int16 y2, int1 color)
#else
void glcd_line(int8 x1, int8 y1, int8 x2, int8 y2, int1 color)
For circles:
| Code: | #ifdef LARGE_LCD
void glcd_circle(int16 x, int16 y, int16 radius, int1 fill, int1 color)
#else
void glcd_circle(int8 x, int8 y, int8 radius, int1 fill, int1 color)
#endif |
etc.
You are using a 320x240 LCD. So clearly, the x-axis requires a 16-bit
value to use the full range of 0 to 319 coordinates. Therefore the
LARGE_LCD value must be defined. Then do a quick check of the files,
and it's not defined. That's likely the problem. Fix it by adding the line
shown in bold below:
| Quote: |
#define LARGE_LCD 1
#include <sed1335.c>
murtis
| No change |
Posted: Wed Jun 04, 2008 4:50 am |
I wrote the code you send me that is below:
| Code: | #define LARGE_LCD 1
#include<graphics.c> |
No change on the glcd screen. _________________ MurtiS |
treitmey
Posted: Wed Jun 04, 2008 10:49 am |
| Perhaps its a timing issue,.. Make all the delays real long as a test. |
murtis
| any error in SED1335.c |
Posted: Thu Jun 05, 2008 12:56 am |
| Quote: | | Perhaps its a timing issue,.. Make all the delays real long as a test. |
I tried this. But, there is no change... Also,i tried to drive with 8-bit and 16-bit. Also, there is no change. I assumed that there are any error in driver SED1335. can it be any error in SED1335.c_? _________________ MurtiS |
murtis
| Perhaps, i will find an error |
Posted: Thu Jun 05, 2008 5:30 am |
Hi again,
I saw that something is wrong like below:
This is from main program
| Code: | | glcd_line(40, 320, 200, 320, ON); |
It must be form like below:
| Code: | | glcd_line(int16 x1, int16 y1, int16 x2, int16 y2, int1 color); |
but something is happening on driver code. this form is changing like below:
| Code: | | glcd_line(int16 x1, int16 y1, int16 x2, int16 y2, int8 color); |
May be, this is a problem.
murtis
| Perhaps! |
Posted: Thu Jun 05, 2008 8:43 am |
Today, i tried the glcd_pixel(int16 x,int16 y,int1 color); code. So, i saw that this appears a problem about the function bit_clear(); or bit_set();. If i try to this main code like below:
| Code: | while(TRUE){
if(!input(PIN_A0))
x=x+1;
glcd_pixel(x,0,OFF);
delay_ms(250);
if(!input(PIN_A1))
y=y+1;
glcd_pixel(0,y,OFF);
delay_ms(250);
some pixel, turned off, goes turning on. So, i understood that there is a problem about function glcd_pixel. But, i could not find any error. Can you look this part of the driver SED1335_?
| Code: | void glcd_pixel(long x, long y, int1 color)
long data;
long addr;
// Calculate the byte address containing the pixel
addr = GLCD_GRAPHICS_ADDR + (GLCD_WIDTH/8 * y + x/8);
// Read the byte of data at the address
data = getData(addr);
// Turn the pixel on or off
if(color == ON)
data |= (1<<(7-x%8));
if(color == OFF)
data &= ~(1<<(7-x%8));
// Write the new data byte to display memory
setData(addr, data);
